Wbucket Clutched February 22, 2010 Share February 22, 2010 Is this possible? Like to heard if the bros here have any views on these? ...... ↡ Advertisement Link to post Share on other sites More sharing options...
Carer 2nd Gear February 22, 2010 Share February 22, 2010 Yes, exhaust fans trying to remove the exhaust will in turn have to work harder. no to mentioned efficiency loses at the ventilation turbines due to friction. always remember, energy cannot be created or destroyed. The best way to tap natural energy the underwater sea waves, winds and solar power. Link to post Share on other sites More sharing options...
Ender Hypersonic February 22, 2010 Share February 22, 2010 Remember seeing a documentary about a building that actually uses the exhaust from the air-con and channel the heat for heating purposes in other areas of the building Link to post Share on other sites More sharing options...
Carer 2nd Gear February 22, 2010 Share February 22, 2010 yes, for heating, energy is put into good use. but maintenance will be expensive. exhaust that travels thru the pipings etc.. need to make sure all seals are working and no leaks. Link to post Share on other sites More sharing options...
Wbucket Clutched February 22, 2010 Author Share February 22, 2010 Ya, I also find it funny that such an idea is formed. Thanks Carer for your reply. Heating in buildings? Other than water, I don't know what else needs to be heated. It would be great if those solar water heater on top of those landed property can be improvised into a multi-level building, condo or HDB. Link to post Share on other sites More sharing options...
Zuoom 1st Gear February 22, 2010 Share February 22, 2010 that's akin to recycling energy that otherwise would have been lost/wasted. couple of issues on hand: is the restriction at the end going to reduce the ventilation capacities? if so, by how much? how effective would the concept be? at what cost? there's always a cost to price ratio. Link to post Share on other sites More sharing options...
Yoongf 4th Gear February 22, 2010 Share February 22, 2010 Take a look at Sg commercial buildings, with all the external blinking lights and the amt of halogen lights used indoors. Are we really serious about energy conservation? From a total cost of ownership perspective, we can save alot more just be doing less. Don't need all these additional gadgets. Link to post Share on other sites More sharing options...
Zizou 2nd Gear February 22, 2010 Share February 22, 2010 back pressure will force the vent to work harder. worst case is the shopping centres will be warmer just to go green the energy produced by the turbine (1kW - 5kW... haha) is small. you save the same amount of money by turning down the thermostat a notch, without additional investment. i was doing quite a lot of work recently on renewable energy for a govt project. what i found out was quite disappointing. we are still years and years away from properly harnessing wind, solar, waves etc. costs are not coming down anytime soon (despite all the advance in solar, its mostly hype), and lots of trial but more errors than anything. however it does gave me an idea for a completely new source which i hope to be the first one to do Link to post Share on other sites More sharing options...
Sunlight 1st Gear February 22, 2010 Share February 22, 2010 It will never work. It is not sustainable as the ROI is too horrible. Forget about large scale govt support, it will not support anything that cannot make $$$. Link to post Share on other sites More sharing options...
Shull Turbocharged February 22, 2010 Share February 22, 2010 Is this possible? Like to heard if the bros here have any views on these? ...... Link to post Share on other sites More sharing options...
Wbucket Clutched February 23, 2010 Author Share February 23, 2010 from a purely engineering point of view, it is workable if it make use of the natural tendency that of hot air rises and use it to turn little turbines.. but to extract any useful amount of energy, you might needs hundreds and thousands of little turbines..so even if this idea passes engineering phase, the finance side will put a stop to it.. Hot air, I haven't thought of that factor. Hot air can be quite strong. Now countries are under-pressure to lower their carbon footprint, so maybe funds would be easier to get than last time. Indeed, lowering energy consumption would beat energy generation anytime. ↡ Advertisement Link to post Share on other sites More sharing options...
2019 2nd Generation Audi Q3
New 5th Generation Honda Stepwagon
The Big Read: Understanding why millennials and Gen Zers feel the way they do about work
