Cymagnus Clutched April 25, 2010 Share April 25, 2010 Hi Benny, I've #845 and want to cut down on the number of stuffs on my car. For regular maintenance, when the water no longer beads, I would just wax over or need to apply some sort of cleaner first? Would you recommend a cleaner wax or a pure cleaner? Do you have any recommendations? Stuffs I have in my storeroom : Mequair's cleaner wax, Autoglym SRP, HiGlaze88, Armorall auto wash. Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Maddriver 4th Gear April 25, 2010 Author Share April 25, 2010 Hi Benny, I've #845 and want to cut down on the number of stuffs on my car. For regular maintenance, when the water no longer beads, I would just wax over or need to apply some sort of cleaner first? Would you recommend a cleaner wax or a pure cleaner? Do you have any recommendations? Stuffs I have in my storeroom : Mequair's cleaner wax, Autoglym SRP, HiGlaze88, Armorall auto wash. Thanks. Hi Magnus..I suggest do a prep again if you find the water bead start to shear off..If you top another layer of 845 without any cleaner..it may not last again which I have tested.. A cleaner wax will do..Meguair or SRP is good enough..I have not try hi-glaze but it semms to have some cleaner in it as well..Try to do this step once a month..use a detailer to maintain between washes.. Link to post Share on other sites More sharing options...
Superman123 Neutral Newbie July 15, 2010 Share July 15, 2010 Hi, After we are done with the 845, do we need to clean the spray head (by maybeo pumping water over?) or leave it on the 845 bottle? If leave it at the 845 bottle, will it dry out and stuck the spray head? thanks! Link to post Share on other sites More sharing options...
Maddriver 4th Gear July 15, 2010 Author Share July 15, 2010 Hi, After we are done with the 845, do we need to clean the spray head (by maybeo pumping water over?) or leave it on the 845 bottle? If leave it at the 845 bottle, will it dry out and stuck the spray head? thanks! It is ok bro..so far my 845 did not clog.. Link to post Share on other sites More sharing options...
Ah_toot Neutral Newbie May 16, 2011 Share May 16, 2011 No problem Bros..In case if you need the spray head..let me know..i will mail to u..is direct fit for collinite 845 bottles.. Can mail me one too? How much does it cost? Link to post Share on other sites More sharing options...
Maddriver 4th Gear May 16, 2011 Author Share May 16, 2011 Can mail me one too? How much does it cost? pm me yr address.. Link to post Share on other sites More sharing options...
Ah_toot Neutral Newbie May 20, 2011 Share May 20, 2011 pm me yr address.. Done le..... Thank you... Link to post Share on other sites More sharing options...
Genes 6th Gear May 20, 2011 Share May 20, 2011 Aiyah feek.... i forgot i wanted this too Link to post Share on other sites More sharing options...
Maddriver 4th Gear May 20, 2011 Author Share May 20, 2011 Done le..... Thank you... Well received Bro.. Link to post Share on other sites More sharing options...
Maddriver 4th Gear May 20, 2011 Author Share May 20, 2011 Aiyah feek.... i forgot i wanted this too No problem Bro..i will be clementi loop this sun morning.. Link to post Share on other sites More sharing options...
Jpcc Clutched May 30, 2011 Share May 30, 2011 Newbie here. In terms of water beading, I find that Duragloss ES beads better than AW. How about Collinite Spray wax? Link to post Share on other sites More sharing options...
Maddriver 4th Gear June 1, 2011 Author Share June 1, 2011 Newbie here. In terms of water beading, I find that Duragloss ES beads better than AW. How about Collinite Spray wax? Hi Jpcc..ES will bead better becos it is a sealant.. AW more of a topper.. Collinite is a wax to be apply on and buff off but we make it with a spray head for easy use.. Link to post Share on other sites More sharing options...
Coupe07 Neutral Newbie June 2, 2011 Share June 2, 2011 benny, is there any adverse effect to add in DG speed detailer into the collinite insulator wax for easier application???? after shaking, i still have the spluttering effect when i use the spray nozzle. This makes the car windows and windscreen very messy... therefore i added a substantial amount of detailer into the insulator wax to dilute it and make it more user frenly.... will there be any adverse effect to minimise the capability of the insulator wax? so far, my observation is nothing, but thats becos my car is seldom out in the sun and rain nowadays.... Link to post Share on other sites More sharing options...
Maddriver 4th Gear June 3, 2011 Author Share June 3, 2011 benny, is there any adverse effect to add in DG speed detailer into the collinite insulator wax for easier application???? after shaking, i still have the spluttering effect when i use the spray nozzle. This makes the car windows and windscreen very messy... therefore i added a substantial amount of detailer into the insulator wax to dilute it and make it more user frenly.... will there be any adverse effect to minimise the capability of the insulator wax? so far, my observation is nothing, but thats becos my car is seldom out in the sun and rain nowadays.... Hi Ivan..I wont recommend to mix any QD in it..May you can try to shake the bottle well and let it turn liquid..spray it on cloth instead..actually 845 is to be use with applicators for application but we have a spray head for easy use.. Link to post Share on other sites More sharing options...
Coupe07 Neutral Newbie June 3, 2011 Share June 3, 2011 Hi Ivan..I wont recommend to mix any QD in it..May you can try to shake the bottle well and let it turn liquid..spray it on cloth instead..actually 845 is to be use with applicators for application but we have a spray head for easy use.. im using the DG spray head from previous used DG bottle. so u wld recommend to shake more to make it watery??? Spray to cloth, the cloth absorb a certain portion liao... making the cloth hard to wash.... add water oso no? Link to post Share on other sites More sharing options...
Maddriver 4th Gear June 6, 2011 Author Share June 6, 2011 im using the DG spray head from previous used DG bottle. so u wld recommend to shake more to make it watery??? Spray to cloth, the cloth absorb a certain portion liao... making the cloth hard to wash.... add water oso no? Yes Bro Ivan..have it more watery and maybe you can try to spray closer to the surface.. Link to post Share on other sites More sharing options...
StoneRocker 1st Gear July 14, 2011 Share July 14, 2011 benny, between 476 n 915 which is more durable? can just apply after car wash? Link to post Share on other sites More sharing options...
Firestorm_33 Neutral Newbie July 15, 2011 Share July 15, 2011 benny, between 476 n 915 which is more durable? can just apply after car wash? personally i find 476 more durable. but then it depends on the color of paint.if yours is a dark color paintwork, and u wan the depth of the color then go for 915. if u want just gloss then go for 476. 915 work best on dark color cars cos it bring out the depth of the color. i would not advise to apply after car wash as the surface may not be prepared for the wax to settle. if u are looking for quick wax, i would suggest DG aquawax instead. ↡ Advertisement Link to post Share on other sites More sharing options...
Please advise bodywork repair, spray painting workshop
Does anyone know a solution to prevent rust on the car?
Spray Painting @ Bt Indah Johor
Which is better? Car Wrap or Spray Painting?
Spray Painting
Spray Painting
STP Carb Spray
STP Carb Spray
Which workshop will remove rim and caliper to spray paint?
Any Cheap / Reasonable Spray Workshop
