Samnet Clutched May 30, 2010 Share May 30, 2010 it seems that Avante ride is much quieter than forte's. Is it due to the sound-clad which comes with avante or tire size? Avante comes with sound clad SP and thicker tires. Or is it due to other reasons??? ↡ Advertisement Link to post Share on other sites More sharing options...
Heartbreakid 6th Gear May 30, 2010 Share May 30, 2010 Sound clad should help only on reducing road noise. I'm not sure if Forte has them. But from my last test drive, I felt that Forte engine noise intrusion is slightly higher than Avante. Along the same stretch of road driving the Avante, regarding road noise, both are about the same due to the traveling speed. I believe Forte 17 inch tyres would generate slightly more road noise. Link to post Share on other sites More sharing options...
Samnet Clutched May 30, 2010 Author Share May 30, 2010 ya. its the road noise that is pretty irritating. the engine noise is ok...... the 17" tires (215/45/R17) is also pretty noisy. Link to post Share on other sites More sharing options...
Windchoco 1st Gear May 31, 2010 Share May 31, 2010 Forte is noisier, think due to lack of soundclad, 17 inch tyres, and the torsion beam which roughens the ride. heck, a forte doesnt even come stock with tuffkote, so theres absolutely nothing on its undercarraige that reduces sound. Link to post Share on other sites More sharing options...
Watwheels Supersonic May 31, 2010 Share May 31, 2010 it seems that Avante ride is much quieter than forte's. Is it due to the sound-clad which comes with avante or tire size? Avante comes with sound clad SP and thicker tires. Or is it due to other reasons??? Size of rims, tires and even suspension contributes to noise levels. Usually softer suspension setup gives less noise. Link to post Share on other sites More sharing options...
Picanto 3rd Gear May 31, 2010 Share May 31, 2010 are you comparing 2 new cars? if its new, there will not be much ratling sounds. its after a few mths later that those sounds will appear. SP can only do so much, it cannot totally eliminate. Link to post Share on other sites More sharing options...
Eric76 1st Gear May 31, 2010 Share May 31, 2010 Forte noise is acceptable to me, never drive avante before but my last ride is Corrolla Link to post Share on other sites More sharing options...
Samnet Clutched May 31, 2010 Author Share May 31, 2010 when i drive over those worn out expressways, especially on the left most lane.....my forte roars!!!! Link to post Share on other sites More sharing options...
Samnet Clutched May 31, 2010 Author Share May 31, 2010 think there wun be much rattling sound since i kept modifications to zero (never tear open doors....or install lights). even my 3yr old cerato is behaving well. just tat engine is a tad noisy, fuel consumption is high. like SUV. Link to post Share on other sites More sharing options...
Samnet Clutched May 31, 2010 Author Share May 31, 2010 my SE gave me tuffkote FOC, so i was thinking of adding sound clad to it....if it does help in reducing road noise.... Link to post Share on other sites More sharing options...
Picanto 3rd Gear June 4, 2010 Share June 4, 2010 when i drive over those worn out expressways, especially on the left most lane.....my forte roars!!!! its a budget car. what do you expect? Link to post Share on other sites More sharing options...
Calvy 1st Gear June 4, 2010 Share June 4, 2010 just test drive forte this week.... engine noise minimal... er......well at least the SE says its much quieter than the Jazz that i am driving now..haha no drive avante before.. but looking forward to Avante 2011... hoho..... Link to post Share on other sites More sharing options...
Samnet Clutched June 4, 2010 Author Share June 4, 2010 only expect it to be as quiet as its counterpart-Avante. Link to post Share on other sites More sharing options...
Sohboonguan 1st Gear June 4, 2010 Share June 4, 2010 my forte is indeed more noisy compare to avante. Tyre, suspension, SP etc. but my engine is also noisy. enigine is very noisy outside, inside, after SP, it is better. nosie for both is acceptable for me. avante less noise, but i pick forte. due to features/spec and styling over noise. :P Link to post Share on other sites More sharing options...
Picanto 3rd Gear June 5, 2010 Share June 5, 2010 only expect it to be as quiet as its counterpart-Avante. tap on the door and the interior plastic. its so hollow. this is the sign of all budget cars. that's where all the rattling noises come from. SP it and feel the difference. Link to post Share on other sites More sharing options...
Informer Neutral Newbie June 5, 2010 Share June 5, 2010 (edited) Yup... It only dissatisfied problem with my Avante is the tire noise intrusion into the cabin... If you compare slamming doors, both the Avante and the Forte... the THUD sound of the Avante is a bit more solid feel... Avante got a comfy ride... Forte (EX) a bit more nimble drive but tire noise is worst then the Avante... Just sharing... Edited June 5, 2010 by Informer Link to post Share on other sites More sharing options...
Sohboonguan 1st Gear June 5, 2010 Share June 5, 2010 I must agree, my forte sx is nosier compare to your avante. i think your avante engine is more refine compare to mine. Tyre also, especially i pump in 250 kpa tyre pressure. make it even more noisy. :P if you guys hear loud engine rev noise and tyre noise. travelling on highway loud like thunder, that could be me, therefore please kindly keep to left lane. :P Link to post Share on other sites More sharing options...
Informer Neutral Newbie June 5, 2010 Share June 5, 2010 Why 250kpa tire pressure..? If not mistaken, for a 205/55/16... the pressure should be just around 220kpa... Please check your tire pressure label sticker at side driver door... ↡ Advertisement Link to post Share on other sites More sharing options...
KIA K3 Owners check-in!
Coolant level going down
