Acevin Clutched July 14, 2010 Share July 14, 2010 I have an autoguage voltmeter. Can know where is a good place which also charge reasonably to install my voltmeter. I had asked couple of workshops ans they are charging between $50 to $80 which I think is quite high.. Also usually voltmeter will be connected to battery or tap from any electronic wiring? which shld b the correct method? Many Thanks.. ↡ Advertisement Link to post Share on other sites More sharing options...
Carer 2nd Gear July 14, 2010 Share July 14, 2010 wa lan.. so easy to install need to pay so much? i diy for u free also np. is it those round type 52 or 60mm? where u wanna install? Link to post Share on other sites More sharing options...
Limiter Neutral Newbie July 14, 2010 Share July 14, 2010 Indeed quite a simple process. If labour is $20, then still acceptable. Link to post Share on other sites More sharing options...
Acevin Clutched July 14, 2010 Author Share July 14, 2010 (edited) wa lan.. so easy to install need to pay so much? i diy for u free also np. is it those round type 52 or 60mm? where u wanna install? Thks Bro.. Duno y I kena quoted so much.. I know esp voltmeter shld b quite easy, but I not very sure if it is to tap to existing supply wire from other electronic or to battery directly.. Mine is the 52mm only.. given to me by my brother.. wana put at the glove slot infront of gear.. But my d wiring left very short length as cut off when he dekit.. Edited July 14, 2010 by Acevin Link to post Share on other sites More sharing options...
Acevin Clutched July 14, 2010 Author Share July 14, 2010 Indeed quite a simple process. If labour is $20, then still acceptable. tink I kena quoted like a carrot.. when they told me, I walked away.. as gd as buying a brand new guage.. Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear July 14, 2010 Share July 14, 2010 yes. Carer is right. just need to tap it to the car battery, that's all. such workmanship, $10-$20 max. lucky you ask here, else kena carrot gao gao. hehe..~ Link to post Share on other sites More sharing options...
Carer 2nd Gear July 15, 2010 Share July 15, 2010 Thks Bro.. Duno y I kena quoted so much.. I know esp voltmeter shld b quite easy, but I not very sure if it is to tap to existing supply wire from other electronic or to battery directly.. Mine is the 52mm only.. given to me by my brother.. wana put at the glove slot infront of gear.. But my d wiring left very short length as cut off when he dekit.. U can always extend the wire. red which is positive, just connect to any positive wire under your steering wheel (take note, make sure its only activated when the iginition is on). for black negative, just tie around any screw that is hidden. if all fails, just connect the red and black to a cig plug, den plug into your cig plug, also can Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 15, 2010 Share July 15, 2010 click here http://www.sunpro.com/publish/2007/09/27/p...glish_16419.pdf This info will be of great help to you Link to post Share on other sites More sharing options...
Acevin Clutched July 15, 2010 Author Share July 15, 2010 U can always extend the wire. red which is positive, just connect to any positive wire under your steering wheel (take note, make sure its only activated when the iginition is on). for black negative, just tie around any screw that is hidden. if all fails, just connect the red and black to a cig plug, den plug into your cig plug, also can Thanks alot bro for ur great advice.. Reason why I resist DIY is cause scare will short-circuit the entire electrical system.. Nevertheless, I will give it a try to DIY.. Link to post Share on other sites More sharing options...
Acevin Clutched July 15, 2010 Author Share July 15, 2010 click here http://www.sunpro.com/publish/2007/09/27/p...glish_16419.pdf This info will be of great help to you Thanks alot bro of the great help... Will give it a try.. Link to post Share on other sites More sharing options...
Acevin Clutched July 15, 2010 Author Share July 15, 2010 However bros, do let me know the workshop that's charging reasonable rate to have the voltmeter guage installed.. Much Thanks Link to post Share on other sites More sharing options...
Ciki Neutral Newbie July 15, 2010 Share July 15, 2010 (edited) i installed a voltage and vacuum for $50.00 bucks...but now think of removing them, any place to recommend for dekit? preferbly in the north area.. Edited July 15, 2010 by Ciki ↡ Advertisement Link to post Share on other sites More sharing options...
Another MU Place To Consider
Know any place that sell Hanes Beefy-T plain tee shirt?
Recommended place to get good Sofa?
How much to install Retractable Awning for home?
Any recommendations to install wooden deck on patio?
Blenheim Palace set to install £1million gold toilet
