Kiadaw 6th Gear July 24, 2010 Share July 24, 2010 (edited) just being curious, does setting the temperature lower means fuel consumption is higher, higher temperature means low fuel consumption? or is it the same amount of fuel consumption regardless of any temperature? I think the difference between ambient temp vs cabin temperature to be set determine the work rate. The bigger the differences, the more work to be done, logically speaking. Also I think air con required more power than heater, so you do the maths So lower temperature not necessary means more fuel consumption. In local context, probably yes. Since almost always the outside temperature is warmer than cabin temperature to set (anytime of the day). Edited July 24, 2010 by Kiadaw ↡ Advertisement Link to post Share on other sites More sharing options...
Happily1986 5th Gear July 24, 2010 Share July 24, 2010 23 degrees celsius Link to post Share on other sites More sharing options...
Happily1986 5th Gear July 24, 2010 Share July 24, 2010 any automakers intoduced inverter technology for their air con or not lol Link to post Share on other sites More sharing options...
Tleslie 1st Gear July 24, 2010 Share July 24, 2010 I think must say wat car lah also. My previous hyundai matrix no digital readout, set the temp knob to coldest always and play with fan speed. Most of time at level 2 (I think total level 4) and max fan speed during hot days. Matrix aircon no good always feel hot. Current ride camry set to auto 24 deg irregardless of outside temp. Toyota air con much more powerful. i experienced the same for my collora then change to accord. Link to post Share on other sites More sharing options...
Troyempire 1st Gear July 24, 2010 Share July 24, 2010 any automakers intoduced inverter technology for their air con or not lol Maybe Mitsubishi car got. Link to post Share on other sites More sharing options...
5936 1st Gear July 24, 2010 Share July 24, 2010 Not to sure abt other makes, toyota hybrids uses invertor aircon. My setting is usually 24 on auto. Link to post Share on other sites More sharing options...
Nullifi3d 4th Gear July 24, 2010 Share July 24, 2010 No temperature to set leh? But the most ideal is to wind down windows and drive faster when its hot. When coming to a stop.... well then thats another problem. Link to post Share on other sites More sharing options...
Seaweed 1st Gear July 24, 2010 Share July 24, 2010 temp min for me....i only change the fan speed when required ... Link to post Share on other sites More sharing options...
Solar Turbocharged July 25, 2010 Share July 25, 2010 ↡ Advertisement Link to post Share on other sites More sharing options...
'Unusually warm' weather may become the norm in Singapore
Workplace temperature
Need Help - High Engine Temperature
Car maintenance in hot weather
High Temperature
High Temperature
Intake temperature
Intake temperature
Temperature keep going up.
Car Exhaust Temperature
