Slowwalker Clutched August 2, 2010 Share August 2, 2010 Hi, any one encounter issue with Singnet broadband when using Qvod player? I tried to bypass the firewall but still failed to steaming. anyone know the port or setting in the 2wire router?? Thanks in advance. ↡ Advertisement Link to post Share on other sites More sharing options...
Mcf777 Turbocharged August 2, 2010 Share August 2, 2010 you must be using OS Vista. I only have problem using OS Vista. Can play. But cannot download. For OS XP (Home/Prof), no problem to download or play. Im also using Singnet. I did not set anything like what u mention : example : firewall Link to post Share on other sites More sharing options...
Slowwalker Clutched August 2, 2010 Author Share August 2, 2010 nope, im using XP Pro. i have no issue with SH when using qvod player till lately i switch to Singtel. Movie seem to be "hanging" at steaming no progress at all after long time. Changed back to SH, everything back to normal. Using the health check from Qvod player, mentioned my firewall blocked it, try to enable HTTP or UDP... hmmmm... since you did not set anything, i'll try to see what i can do... Link to post Share on other sites More sharing options...
Fcw75 Hypersonic December 20, 2011 Share December 20, 2011 Is anyone using QVOD here? Is it safe to use? Any trojan virus? Link to post Share on other sites More sharing options...
Happily1986 5th Gear December 20, 2011 Share December 20, 2011 Hi, any one encounter issue with Singnet broadband when using Qvod player? I tried to bypass the firewall but still failed to steaming. anyone know the port or setting in the 2wire router?? Thanks in advance. QVOD is simply a form of bittorrenting. even though i didn't enable port forwarding for that client, it still works. it should. i tested it on Win XP Pro SP3 x86, XP Home SP3, Win 7 Starter x86 SP1 and Win 7 x64 Ultimate and they all work. ↡ Advertisement Link to post Share on other sites More sharing options...
Fibre broadband
Fibre broadband
Any regular casino slots player here?
