Kungfu Clutched September 11, 2010 Share September 11, 2010 For car using this type of P/S,although there are really nothing to note and is supposed to be "maintenance free", is it really true nothing to be wary of. Like steering coupling/servo operation/steering cooling fan etc............ Any body can advise??? ↡ Advertisement Link to post Share on other sites More sharing options...
Chickensoup 1st Gear September 11, 2010 Share September 11, 2010 No different in terms of maintenance vs those belt driven version. Occasionally you still have to check the power steering fluid level, same as the belt type. Link to post Share on other sites More sharing options...
Boyboy 1st Gear September 11, 2010 Share September 11, 2010 (edited) No different in terms of maintenance vs those belt driven version. Occasionally you still have to check the power steering fluid level, same as the belt type. sure or not? I was under the impression that the electric motor doesn't operate on hydraulic pressure, therefore no PS fluid needed Power Steering Wiki sounds quite maintenance free to me. unless the thing spoils then need to repair/replace. much like air con compressor Edited September 11, 2010 by Boyboy Link to post Share on other sites More sharing options...
Kungfu Clutched September 11, 2010 Author Share September 11, 2010 No different in terms of maintenance vs those belt driven version. Occasionally you still have to check the power steering fluid level, same as the belt type. Problem is...........no fluid to check,no belts to see, no sound to listen to..............dun even know when there's a problem...........until there's a problem. Link to post Share on other sites More sharing options...
Subarugt Neutral Newbie September 11, 2010 Share September 11, 2010 from a mark x? Link to post Share on other sites More sharing options...
Dscheng 3rd Gear September 11, 2010 Share September 11, 2010 Check your head la. Electric steering don't have powersteering fiuld la Link to post Share on other sites More sharing options...
Achtung 6th Gear September 11, 2010 Share September 11, 2010 Its is maintenance free. Was shocked to see someone suggest checking the fluid lol My second ride is a Fiat and they use such Electrical Power Steering. When its gonna 'up lorry', there is a weird humming sound. After which, u lose power steering intermitently. Of course, the wonderful TTS quoted me more than S$6k for the repair. Being a car enthusiasts, I did my due diligence and it cost only 530 Link to post Share on other sites More sharing options...
Friendstar Supercharged September 11, 2010 Share September 11, 2010 Its is maintenance free. Was shocked to see someone suggest checking the fluid lol My second ride is a Fiat and they use such Electrical Power Steering. When its gonna 'up lorry', there is a weird humming sound. After which, u lose power steering intermitently. Of course, the wonderful TTS quoted me more than S$6k for the repair. Being a car enthusiasts, I did my due diligence and it cost only 530 Link to post Share on other sites More sharing options...
Achtung 6th Gear September 11, 2010 Share September 11, 2010 With two years warranty, ok lar..... its still very expensive leh.... electric power steering seems like a NO NO Link to post Share on other sites More sharing options...
Kungfu Clutched September 11, 2010 Author Share September 11, 2010 wow, so expensive to repair such PS.........is there any manner we can prolong the life of such PS Link to post Share on other sites More sharing options...
Achtung 6th Gear September 13, 2010 Share September 13, 2010 I dont think so.... wow, so expensive to repair such PS.........is there any manner we can prolong the life of such PS Link to post Share on other sites More sharing options...
Dscheng 3rd Gear September 13, 2010 Share September 13, 2010 s--t.. My japanese ride come wif electric power steering too. if spoilt, sure cost big bomb ! Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged September 13, 2010 Share September 13, 2010 workshop in SG quote me $2k+ for power steering... exclude labour my malaysia workshop that specialises in honda... quote me RM700+ include labour.... Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear September 13, 2010 Share September 13, 2010 For car using this type of P/S,although there are really nothing to note and is supposed to be "maintenance free", is it really true nothing to be wary of. Like steering coupling/servo operation/steering cooling fan etc............ Any body can advise??? All electrics have the traditional conductivity issue. Example: good when new only. Even if there is regular servicing done. When the time comes for you to pay for expensive replacement. What do you say? Link to post Share on other sites More sharing options...
Passion 5th Gear September 13, 2010 Share September 13, 2010 Electronic steering wheel unlike normal steering wheel,not advisable to keep turning from left to right and back to left,it'll burn the electronic device inside due to it need to keep supplying electricity to the electric motor to assist the turn of the steering wheel.This is the advice from the Toyota Manual. Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear September 13, 2010 Share September 13, 2010 Electronic steering wheel unlike normal steering wheel,not advisable to keep turning from left to right and back to left,it'll burn the electronic device inside due to it need to keep supplying electricity to the electric motor to assist the turn of the steering wheel.This is the advice from the Toyota Manual. so what u are saying is that try to travel straight la if your car is equipped with electric power steering? Link to post Share on other sites More sharing options...
Dscheng 3rd Gear September 13, 2010 Share September 13, 2010 hahahah.. Crap sia.. Then what is steering wheel for !! Link to post Share on other sites More sharing options...
Darkblue 1st Gear September 14, 2010 Share September 14, 2010 Now the new vehicles (Jap/Kor) are coming with electronic power steering..... most of the time feels over-assisted, very numb steering feel. When I drove a Honda Freed, there was once power steering spoil, suddenly the steering will jam, power cut off making turning very very difficult. Imagine if lady drivers have no strength to manoeuvre... Crap design, so dangerous. ↡ Advertisement Link to post Share on other sites More sharing options...
Steering leather wrapping
Home power back up
Home power back up
Steering column
Steering column
Alcades power optimizer
