Moredhel 2nd Gear September 23, 2010 Share September 23, 2010 Using Son_x. Just add a little in before filling up with water now and then. So far it seems to give a cleaner feel and solves squeaking wipers problem when used. Guess alkaline still works. Maybe one of these days I'll use my mum's glass cleaner. ↡ Advertisement Link to post Share on other sites More sharing options...
5936 1st Gear September 23, 2010 Share September 23, 2010 (edited) I will only use additive so long as this bottle of Son-x last. 5 mls to 5L is the max for me. So maybe I am looking at 1+ year to say bye bye to this bottle. Yes it help to lubricate wiper. Edited September 23, 2010 by 5936 Link to post Share on other sites More sharing options...
Zafchen Neutral Newbie October 8, 2010 Share October 8, 2010 Hi Icy..it is recommended not to use any chemical or shampoo mixed in reservoir..I would recommend use distilled water..grab 1 bottle from 7 eleven or any kiosk.. the reason..for all this chemical..once it is dry..some may leave etch marks on surface and especially nozzle is on the bonnet..The best is carry one glass cleaner in your car..do it externally.. bro,, how about mixed with 2 cap of glass cleaner? Link to post Share on other sites More sharing options...
Krismas Neutral Newbie October 8, 2010 Share October 8, 2010 bro,, how about mixed with 2 cap of glass cleaner? I heard of people using glass cleaner to rid the surface of any polishing oil to inspect whether they really did polish the defects off. So I would think that if the glass cleaner touches the paint it would strip the wax/sealant/protection on the paint as well....or did you mean 2 caps of those windshield wiper fluid? Link to post Share on other sites More sharing options...
Zafchen Neutral Newbie October 8, 2010 Share October 8, 2010 I heard of people using glass cleaner to rid the surface of any polishing oil to inspect whether they really did polish the defects off. So I would think that if the glass cleaner touches the paint it would strip the wax/sealant/protection on the paint as well....or did you mean 2 caps of those windshield wiper fluid? what i mean is... pour in 2 cap of glass cleaner, than mix with plain water till the reservoir is full Link to post Share on other sites More sharing options...
Krismas Neutral Newbie October 8, 2010 Share October 8, 2010 what i mean is... pour in 2 cap of glass cleaner, than mix with plain water till the reservoir is full Let's do a bit of calculation here and forgive me if I'm a bit OCD. Assuming its Megs Glass Cleaner Concentrate, recommended dilution is 10:1. Assuming the reservoir can hold 5lit of water and 2 caps is 2oz = approx. 60ml. So what's in the reservoir would be around 100:1 dilution. 1. That's a pretty weak dilution for it to be effective in cleaning. 2. Class cleaner are suppose to be sprayed on and wiped off. You could get away with it on the windscreen, but there would be overspray/run-off on the paint and it *could* leave stain on the surface if not wiped. 3. Assuming that dilution can clean, it *could also* clean away the existing wax/protection on the paint on the oversprayed/ran-off area. If you want to be sure, check the dilution ratio if you mixed it in the reservoir. Mix a little of it in a spray bottle or something and try spraying and leaving it on an inconspicuous area and see what happened. A lot of assumptions up there but I would think you'd get the idea. Or take the easy way out - fill it with distilled water. Link to post Share on other sites More sharing options...
Timex1441 1st Gear October 8, 2010 Share October 8, 2010 what i mean is... pour in 2 cap of glass cleaner, than mix with plain water till the reservoir is full Must check whether the glass cleaner contains ammonia....household glass cleaners that contain ammonia are too strong for cars....might damage your paint Link to post Share on other sites More sharing options...
Maddriver 4th Gear October 8, 2010 Share October 8, 2010 what i mean is... pour in 2 cap of glass cleaner, than mix with plain water till the reservoir is full Zaf..I only recommend water in the tank..like what Krismas mentioned.. Link to post Share on other sites More sharing options...
Maddriver 4th Gear October 8, 2010 Share October 8, 2010 Must check whether the glass cleaner contains ammonia....household glass cleaners that contain ammonia are too strong for cars....might damage your paint u got it bro..there are different between household glass cleaner and car glass cleaner..the latest glass cleaner that i have can be used on tinted film.. Link to post Share on other sites More sharing options...
Zafchen Neutral Newbie October 9, 2010 Share October 9, 2010 Roger that bro... thanks, i will use plain water from now on.. :) Link to post Share on other sites More sharing options...
Newage Neutral Newbie October 9, 2010 Share October 9, 2010 plain water is the best! cost effective and safe... Link to post Share on other sites More sharing options...
flashbang Turbocharged August 20, 2016 Share August 20, 2016 Any recommendations for wiper fluid? Looking to try either rain x or sonax... meanwhile rinsing out my tank by using plain water. Link to post Share on other sites More sharing options...
Kangadrool Supersonic August 20, 2016 Share August 20, 2016 (edited) Already telledededededededed.... use plain h2o the bestest. Every two days, activate spray and wipe, good for tank, motor, wiper, pump... Edited August 20, 2016 by Kangadrool 2 Link to post Share on other sites More sharing options...
Blueray Hypersonic August 20, 2016 Share August 20, 2016 I use the blue colour one from NTUC. think its $1.80 per bottle. good enough for me. Link to post Share on other sites More sharing options...
Glyuen 3rd Gear August 20, 2016 Share August 20, 2016 I have been using SONAX Clear View 1:100. Quite satisfied with it, after trying many products. Link to post Share on other sites More sharing options...
ValentinoRyan 1st Gear August 23, 2016 Share August 23, 2016 I saw some windscreen wiper tablets, think it will work better than those big bottle ones. Link to post Share on other sites More sharing options...
Mcf777 Turbocharged August 23, 2016 Share August 23, 2016 i used Duragloss No-rinse for the water tank. Supper clear Ar ga ar ga.....dont pour too much. 1 Link to post Share on other sites More sharing options...
flashbang Turbocharged August 28, 2016 Share August 28, 2016 Already telledededededededed.... use plain h2o the bestest. Every two days, activate spray and wipe, good for tank, motor, wiper, pump... Plain water no lubrication and doesn't clear away dirt, especially when sometimes got some white specks stuck to the windscreen. With washer fluid, one spray and wipers stop squeaking. I have been using SONAX Clear View 1:100. Quite satisfied with it, after trying many products. Autobacs had offer so bought this to try, so far so good, cleans quite well. ↡ Advertisement Link to post Share on other sites More sharing options...
Which brand of honey to buy?
Which airline is the best?
