Ag123 Neutral Newbie January 2, 2011 Share January 2, 2011 oil prices are going up, i'm also trying spark plug upgrades on an old set of spark plug on a accent clocked some 70+ K km prior to this changed air filter, strangly fuel economy improved from 10+, 11 km / liter to ~ 12 km / liter so next 'mod' is a fine tipped spark plug, surprisingly a supporting article on spark plug fuel economy is found from planes http://www.ramaircraft.com/Maintenance-Tip...-vs-Massive.htm "RAM flight test data has shown fine wire spark plugs to be around 2.2% more efficient than massive electrode spark plugs. The TSIO-520-NB engine at high cruise or climb power ( 232 hp at 2400 RPM; EGT at Peak +100 ↡ Advertisement Link to post Share on other sites More sharing options...
Yeobh 4th Gear January 4, 2011 Share January 4, 2011 (edited) Cancel Edited January 4, 2011 by Yeobh Link to post Share on other sites More sharing options...
Yeobh 4th Gear January 4, 2011 Share January 4, 2011 " How To Get The Perfect Spark Plug Gap! " video Click Here http://www.youtube.com/watch?v=l5v1XVSCY-U Link to post Share on other sites More sharing options...
Ag123 Neutral Newbie January 8, 2011 Share January 8, 2011 (edited) new spark plug verdict is out (those expensive Iridium type) before esso 5000 10.93 l / km - 236 km change paper air filter - 12.02 l / km - 239 km new Iridium spark plugs - 12.18 l /km - 184 km caltex 98 - 10.1 l /km - 231 km esso 5000 - 10.46 l/km - 186 km 50% highway / 50 % city note mixture of different driving conditions for the above, those 12.02 l / km probably have more uncongested highway %, vs city driving new Iridium spark plugs makes almost imperceptible improvement to fuel economy Edited January 8, 2011 by Ag123 Link to post Share on other sites More sharing options...
Voxy28 3rd Gear January 8, 2011 Share January 8, 2011 new spark plug verdict is out (those expensive Iridium type) before esso 5000 10.93 l / km - 236 km change paper air filter - 12.02 l / km - 239 km new Iridium spark plugs - 12.18 l /km - 184 km caltex 98 - 10.1 l /km - 231 km esso 5000 - 10.46 l/km - 186 km 50% highway / 50 % city note mixture of different driving conditions for the above, those 12.02 l / km probably have more uncongested highway %, vs city driving new Iridium spark plugs makes almost imperceptible improvement to fuel economy If spark plug can improve performance, then all those doctorates developers will use it as a key parameters in engine design. Just use recommended stock plugs will do. My friends spork car only use recommended bosch plat.. ea $6 nia. Dont be a gong kia... Link to post Share on other sites More sharing options...
Ag123 Neutral Newbie January 10, 2011 Share January 10, 2011 (edited) If spark plug can improve performance, then all those doctorates developers will use it as a key parameters in engine design. Just use recommended stock plugs will do. My friends spork car only use recommended bosch plat.. ea $6 nia. Dont be a gong kia... rats shd've hunt for bosch plat btw bosch plat are good plugs, i didn't run enuf places to find them http://rb-aa.bosch.com/boaa-sg/Product.jsp...p;publication=1 http://rb-aa.bosch.com/boaa-sg/Product.jsp...p;publication=1 btw not totally placebo effect lah, now engine rev better, so i tend to rev more from traffic light + travel nearer to speed limit on e-way Edited January 10, 2011 by Ag123 Link to post Share on other sites More sharing options...
Stanchiam 1st Gear February 15, 2011 Share February 15, 2011 oil prices are going up, i'm also trying spark plug upgrades on an old set of spark plug on a accent clocked some 70+ K km prior to this changed air filter, strangly fuel economy improved from 10+, 11 km / liter to ~ 12 km / liter so next 'mod' is a fine tipped spark plug, surprisingly a supporting article on spark plug fuel economy is found from planes http://www.ramaircraft.com/Maintenance-Tip...-vs-Massive.htm "RAM flight test data has shown fine wire spark plugs to be around 2.2% more efficient than massive electrode spark plugs. The TSIO-520-NB engine at high cruise or climb power ( 232 hp at 2400 RPM; EGT at Peak +100 Link to post Share on other sites More sharing options...
Ag123 Neutral Newbie February 16, 2011 Share February 16, 2011 (edited) new spark plug verdict is out (those expensive Iridium type) before esso 5000 10.93 l / km - 236 km change paper air filter - 12.02 l / km - 239 km new Iridium spark plugs - 12.18 l /km - 184 km caltex 98 - 10.1 l /km - 231 km esso 5000 - 10.46 l/km - 186 km 50% highway / 50 % city note mixture of different driving conditions for the above, those 12.02 l / km probably have more uncongested highway %, vs city driving new Iridium spark plugs makes almost imperceptible improvement to fuel economy esso synergy 5000 253 km 11.57 km / l synergy 5000 158 km 10.57 km / l synergy 5000 244 km 11.13 km / l synergy 5000 179 km 12.29 km / l synergy 5000 216 km 11.71 km/l synergy 5000 228 km 13.11 km/l after another thousand km or so, had to say new Iridium spark plugs may have made a minor improvement fuel economy has gone from10.x km / l to about 11.x km / l (but whether the contribution is due to it being new or being Iridium and fine tipped is hard to tell, i guess it is a contribution from the combined effect) also slightly changed driving habits e.g. driving average 70-85 km/h (only occasional 90 km/h on highways) when it is not necessary to drive fast (this could also have contributed to fuel savings, as aerodynamic drag eats up energy at the cube of your speed http://en.wikipedia.org/wiki/Drag_(physics)#Power, a small change in max speed can make a bigger diff in energy lost to drag and allow your car to run at lower rev thus saving fuel) note that my old copper spark plugs are too cold (wrong heat range) a bit burnt out look (slight fouling) in a car which has been driven tens of thousands of km prior to the change. hence it may be worth changing copper spark plugs which have been worn out or is having fouling problem etc (note: choose the right heat range for your car according to your manuals etc, for some performance cars hot plugs could be too hot & can cause pre-ignition which i think is a worse problem) Edited February 16, 2011 by Ag123 ↡ Advertisement Link to post Share on other sites More sharing options...
Music Concerts
Music Concerts
ERP rates increase/decrease thread monitor!
Changing of Spark Plugs
RS Chip Tuning
RS Chip Tuning
Town Council S&C Charges May Increase Soon!
Tool to change Spark Plug
