Tianmo Hypersonic October 9, 2010 Share October 9, 2010 Was looking all over MCF, but could not find any topic on DIY change ATF. Anybody here DIY change ATF? where do we refill the ATF, I can't find any place expect the dipstick, but how do we know how much to fill and not to over fill? ↡ Advertisement Link to post Share on other sites More sharing options...
Nikrome_wire Neutral Newbie October 9, 2010 Share October 9, 2010 the 'change' of ATF is only partial, and most people take their cars to be flushed. yes, you are right, only fill up point is at the dipstick hole. so gotta pour the fresh fluid in very slowly. how not to over fill? quite simply drain out all the fluid from the sump, and measure the amount that came out. a rough measurement will do. when filling up, fill till the bottom marking of the dipstick. run your car for a few KM, and do necessary filling. this allows the fluid to be heated up and expanded. Link to post Share on other sites More sharing options...
Fresh Clutched October 9, 2010 Share October 9, 2010 how are you going to dispose of the ATF? Link to post Share on other sites More sharing options...
Limws1 1st Gear October 9, 2010 Share October 9, 2010 Don't DIY unless you have means to dispose of the used ATF. Always replace the AT transmission filter when you replace ATF to ensure no residue trapped in the old filter get circulated with clean ATF. Link to post Share on other sites More sharing options...
Mini-itx Clutched October 9, 2010 Share October 9, 2010 Its hard to DIY ATF change. Cause you usually need to remove the hose and pump the fluid into the transmission. Also, you will have to remove the pan below the transmission in order to change the filter. Its not easy and rather messy. Link to post Share on other sites More sharing options...
Breadandwater April 3, 2011 Share April 3, 2011 Very messy but it is possible. It is much easier to change the oil. Link to post Share on other sites More sharing options...
KARTer 2nd Gear April 4, 2011 Share April 4, 2011 Was looking all over MCF, but could not find any topic on DIY change ATF. Anybody here DIY change ATF? where do we refill the ATF, I can't find any place expect the dipstick, but how do we know how much to fill and not to over fill? from experience it seems atf refill needs some kind of pump .......... but this may depend on the make/model of the car you drive... Link to post Share on other sites More sharing options...
Aloytryp Neutral Newbie April 4, 2011 Share April 4, 2011 I DIY before and quite messy la. Make sure the fluid is not very hot... warm is ok. I draw the ATF from the dipstick hole as much as I can and than refill new fluid. The next 1 - 2 days did the same thing. Total I did 3 round. Important * Remember to check the ATF level in case overfilled. Link to post Share on other sites More sharing options...
KARTer 2nd Gear February 20, 2012 Share February 20, 2012 I DIY before and quite messy la. Make sure the fluid is not very hot... warm is ok. I draw the ATF from the dipstick hole as much as I can and than refill new fluid. The next 1 - 2 days did the same thing. Total I did 3 round. Important * Remember to check the ATF level in case overfilled. saw workshop use machine to suck the old atf out.... at home no machine to suck Link to post Share on other sites More sharing options...
Yeobh 4th Gear February 20, 2012 Share February 20, 2012 Attached info on manually operated ATF dispenser. Accuracy in (total volume dispensing) ATF to the transmission is very important. Link to post Share on other sites More sharing options...
Yeobh 4th Gear February 20, 2012 Share February 20, 2012 (edited) For sucking out ATF,use a hand operated vacuum pump or oil suction gun Edited February 20, 2012 by Yeobh Link to post Share on other sites More sharing options...
MacDuck 1st Gear February 24, 2012 Share February 24, 2012 For sucking out ATF,use a hand operated vacuum pump or oil suction gun Where can we buy such a pump locally? Link to post Share on other sites More sharing options...
Yeobh 4th Gear February 24, 2012 Share February 24, 2012 Just PM you Link to post Share on other sites More sharing options...
Lsm_83 2nd Gear February 24, 2012 Share February 24, 2012 I would like to check what is the average cost for replacing the oil plus labour? I was charged $90 for my verna. This is the first time i replacing my ATF oil. ↡ Advertisement Link to post Share on other sites More sharing options...
Tool to change Spark Plug
Change Disc Rotors
Change Disc Rotors
Anybody know what happened eventually?
X for twitter change request
Iceland : Has anybody driven in Iceland before?
