Kungfu Clutched November 18, 2010 Share November 18, 2010 my car starts to give me the occasional, but noticeable jerk at times,esp when it's 50km'h or below. I really not sure what is causing it but really discomfort taking the jerks. could it be - the accelerator starts to loosen or become not sensitive - fuel filter becomes v dirty,must change - that i used a btl of http://www.marvelmysteryoil.com/index.php/site/mmo/ - other reasons that i yet heard of ↡ Advertisement Link to post Share on other sites More sharing options...
13177 Hypersonic November 19, 2010 Share November 19, 2010 Often i heard car vibrate at times when it is 50km/h or below?! Link to post Share on other sites More sharing options...
Hamburger Hypersonic November 19, 2010 Share November 19, 2010 misfiring.....check the plugs. If copper type, change it as its cheap. Link to post Share on other sites More sharing options...
Kungfu Clutched November 19, 2010 Author Share November 19, 2010 misfiring.....check the plugs. If copper type, change it as its cheap. cannot be.....i bought the same plugs meant for toyota sienta from hexing??? now i suspect could be the fuel filter Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged November 19, 2010 Share November 19, 2010 cannot be.....i bought the same plugs meant for toyota sienta from hexing??? now i suspect could be the fuel filter how long have you used your spark plugs without changing? i suggest removing the spark plugs to inspect visually. Link to post Share on other sites More sharing options...
Rayoh Neutral Newbie November 19, 2010 Share November 19, 2010 Could be the faulty spark plug... Misfiring Encountered this problem couple of years back. Mechanic checking high and low for problem. Finally, change the spark plug and problem solved. Link to post Share on other sites More sharing options...
Kungfu Clutched November 19, 2010 Author Share November 19, 2010 (edited) i just changed my plugs........they're the same bought from he xing,4get to mention.....the jerking seem to be from the rear....not from the engine Edited November 19, 2010 by Kungfu Link to post Share on other sites More sharing options...
JonEthan Neutral Newbie November 19, 2010 Share November 19, 2010 if plugs are fine, you might want to check the wires connecting to the spark plugs. Little crack on the insulation can let the voltage slip out. Link to post Share on other sites More sharing options...
Kungfu Clutched November 19, 2010 Author Share November 19, 2010 if plugs are fine, you might want to check the wires connecting to the spark plugs. Little crack on the insulation can let the voltage slip out. okkkkkkkkkkk, will chk, din know that little crack on the insulation can let the voltage slip out. Link to post Share on other sites More sharing options...
Kungfu Clutched November 23, 2010 Author Share November 23, 2010 (edited) i can now more or less confirm the jerking is after using the btl of marvel mystery oil. now the jerking noticeably less,probably the mystery oil washing off slowly Edited November 23, 2010 by Kungfu Link to post Share on other sites More sharing options...
Wavedancer Neutral Newbie November 23, 2010 Share November 23, 2010 Sounds interesting, I was just commenting in the thread, Cheating Motor Workshop about something quite similar. Workshops will try to push products claiming that it will improve the performance and/or mileage but turns out to be useless in the end. One of the products mentioned was flushing of engine, done by workshop but not recommended anything in the manual. Is yours something similar to flushing or claim to clean the engine? Link to post Share on other sites More sharing options...
Joemit7850 1st Gear November 23, 2010 Share November 23, 2010 i can now more or less confirm the jerking is after using the btl of marvel mystery oil. now the jerking noticeably less,probably the mystery oil washing off slowly is the jerking only when you car in stationary D mode? if yes, could be the wire link to the spark plug. that's happen to my swift few week back and spend few hundered to change it. Link to post Share on other sites More sharing options...
Kungfu Clutched November 24, 2010 Author Share November 24, 2010 Can visit the marvel mystery oil website.....now the jerking almost gone. This is the the only additive that can be added to both the fuel and the engine oil........guess too thick for the fuel....cannot tahan.....pump few more times ok liao....scared...will avoid all these fuel additives in future. Link to post Share on other sites More sharing options...
Wavedancer Neutral Newbie November 24, 2010 Share November 24, 2010 Good idea Link to post Share on other sites More sharing options...
Kungfu Clutched November 25, 2010 Author Share November 25, 2010 just now forgot to switch off headlight for near 2 hrs...............now cannot start car.........haiz........must jump start liao. Link to post Share on other sites More sharing options...
Hamburger Hypersonic November 25, 2010 Share November 25, 2010 battery is also weak liao............. Link to post Share on other sites More sharing options...
Moredhel 2nd Gear November 25, 2010 Share November 25, 2010 Think someone got a very nice bridge to sell you. ↡ Advertisement Link to post Share on other sites More sharing options...
Online purchase for car parts
i Wake Up Naked Today Morning
ODO Mileage Tampering
Enzo car mats
Enzo car mats
