Haziqko Clutched December 19, 2010 Share December 19, 2010 Thanks for all the advise, here's the information, Car : Saab 9-5 (Nov'06) Tyre : Eagle F1 (approx. 25k km), 235/45R17 Symptom: "woong, woong" noise is heard between 70-90km/h, can hear from inside car w/ window closed, started about ~10k km ago, but more obvious recently Others : rotate tyre every 10k km. Done 4 wheel alignment and wheel balancing 5k km ago Changed the front support bearing, front arm bearing, thrust bearing and suspension bump stopper about 34k km ago (before current tyre). Tyre pressure : 38psi (manufacturer recommended 36psi) could be both the tyres and the bearings gone. The tyres are sure noisy when worn out and the bearings could be gone also. tire pressure seemed ok. i pump +4psi on all wheels and find that it becomes a bit noisy too. ↡ Advertisement Link to post Share on other sites More sharing options...
Zuke Neutral Newbie December 19, 2010 Share December 19, 2010 Agreed, had the same problem on my ride Fit. Need to check all 4 tires. Usually its the back wheel bearing. Hope that help Link to post Share on other sites More sharing options...
Roberttan 5th Gear December 20, 2010 Share December 20, 2010 (edited) replies here are all just adviced base on your quotes. so the best is go to your workshop or tyre mech to have physicall inspect on both tyre and test drive it ,An experience mech should able to solove your problem. self medication could cost you your LIFE (best consult your doctor but cost your consultation fee ) seld medication does help you to save money but be responsible to yourself. Edited December 20, 2010 by Roberttan Link to post Share on other sites More sharing options...
Accord Clutched December 20, 2010 Share December 20, 2010 Bro, time to change your tyres. I'm facing the same problem too. Likely is due to absorber that causes unbalance thread that make the sound:) Link to post Share on other sites More sharing options...
Skywalker Neutral Newbie December 20, 2010 Author Share December 20, 2010 Thanks for all the advise, learnt something new again. Will get my car check. Link to post Share on other sites More sharing options...
Tazstar88 Neutral Newbie December 20, 2010 Share December 20, 2010 I recently changed my tires to Falken Ziex912, there is a constant "humming" sound when the car is moving more than 50km/h. I did not have this issue when I am on previous Federal tires. I got C&C to check my bearings and even the chassis, all are well. I even went do a high speed balancing for the front wheels but the noise is still there. So my conclusion, must be the tires. It seems that Falken tires have this "humming" noise issue with certain cars... Link to post Share on other sites More sharing options...
Evillusion Supersonic December 20, 2010 Share December 20, 2010 Bro u got a very happy tyres since they are humming away! Lucky not humping sound! Link to post Share on other sites More sharing options...
Roberttan 5th Gear December 20, 2010 Share December 20, 2010 I recently changed my tires to Falken Ziex912, there is a constant "humming" sound when the car is moving more than 50km/h. I did not have this issue when I am on previous Federal tires. I got C&C to check my bearings and even the chassis, all are well. I even went do a high speed balancing for the front wheels but the noise is still there. So my conclusion, must be the tires. It seems that Falken tires have this "humming" noise issue with certain cars... if your tyre(never mentioned the brand) got the humming noise immediately after the changed i tell you you can throw away this tyre. noise like this is either from tyre or wheel bearing also happen the dented wheel(very rare). Please dont waste your time or money go and balance /high speed balance/ check absober/spring. Link to post Share on other sites More sharing options...
Help1 1st Gear December 20, 2010 Share December 20, 2010 my hump my hump, my hump, my hump, my hump, my hump my hump, my hump, my hump, my lovely little lumps OR Mee Siam Mai Hump..... Link to post Share on other sites More sharing options...
Tazstar88 Neutral Newbie December 21, 2010 Share December 21, 2010 I hear this Falken 912 has high wear rate about 20k, so the next change will be Hankook I did use the old V8RS on my previous ride and the wet grip was "No horse run" especially when I am travelling on NSH. ↡ Advertisement Link to post Share on other sites More sharing options...
Tyre puncture
Tyre puncture
Continental closing Alor Setar plant
Portable Tyre Pump
Portable Tyre Pump
Continental CSC 7.
Continental CSC 7.
