BBsyah Neutral Newbie December 18, 2010 Share December 18, 2010 hi friends of MCF.. need some help here.. I am driving a 06 swift... recently when stop to go.. gear 1 to gear 2.. rev and suddenly my handbrake sign on my meter board lights up.. what happen?? after changing to gear 2.. it turn off.. after that rev again.. then light comes on again.. but after gear 3 onwards no such problem.. Can someone tell me what is this that i am facing? Thank you for the constructive help.. ↡ Advertisement Link to post Share on other sites More sharing options...
Xers007 Supercharged December 18, 2010 Share December 18, 2010 You accelerate too fast already your car auto brake to slow you down.... .... maybe the handbrake sensor spoil or came loose? 4 yrs old car things starting came loose already... Link to post Share on other sites More sharing options...
I-LOVE-CARS 1st Gear December 18, 2010 Share December 18, 2010 You accelerate too fast already your car auto brake to slow you down.... .... maybe the handbrake sensor spoil or came loose? 4 yrs old car things starting came loose already... Yep...Better to have a check at Suzuki Service center...maybe due to wear and tear? Link to post Share on other sites More sharing options...
Eds Neutral Newbie December 18, 2010 Share December 18, 2010 Brake oil level low,top up. Link to post Share on other sites More sharing options...
BBsyah Neutral Newbie December 18, 2010 Author Share December 18, 2010 Brake oil level low,top up. hmmm need to ask someone to check.. any idea how much is brake oil? Link to post Share on other sites More sharing options...
Lucaswh 1st Gear December 18, 2010 Share December 18, 2010 hmmm need to ask someone to check.. any idea how much is brake oil? yup facing same problem. brake fluid level is low. did a shelf check and see the prices can be around $10 for a 250ml bottle. (if i rem correctly) maybe we can share a bottle. Link to post Share on other sites More sharing options...
BBsyah Neutral Newbie December 18, 2010 Author Share December 18, 2010 yup facing same problem. brake fluid level is low. did a shelf check and see the prices can be around $10 for a 250ml bottle. (if i rem correctly) maybe we can share a bottle. how to make a check? from where bro? Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear December 18, 2010 Share December 18, 2010 You accelerate too fast already your car auto brake to slow you down.... .... maybe the handbrake sensor spoil or came loose? 4 yrs old car things starting came loose already... If you are kidding with us, this is ticklish Can share with us when you invented such device? Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear December 18, 2010 Share December 18, 2010 how to make a check? from where bro? Open bonnet and look at the Brake Fuild Reservior. If brake fluid bekow the mark: low, you need to top it up. If you see nothing, do not drive car anywhere. Top up brake fluid first (there is a leak somewhere). Otherwise arrange to tow it to workshop. Car brakes can fail if not enough brake fluid (more costly) Link to post Share on other sites More sharing options...
Eds Neutral Newbie December 19, 2010 Share December 19, 2010 Pop up ur bonnet is on ur left hand side. is grey color cover just turn Open and top up to the indicate level will do. Link to post Share on other sites More sharing options...
BBsyah Neutral Newbie December 19, 2010 Author Share December 19, 2010 Thanks for the help.. Cause when I open the cap.. It became a thick and solid liquid.. Drove to a workshop.. They pump out the old brake fluid and clean.. Then top up with shell brake fluid.. Now the car runs well.. Thank u mcf forumers Link to post Share on other sites More sharing options...
M3taph0r Neutral Newbie December 22, 2010 Share December 22, 2010 hi peeps! ↡ Advertisement Link to post Share on other sites More sharing options...
MOM help FTs look for jobs ?
Home repair advice needed
Computer advice needed
