Coolant flush kit
Stanchiam
Btw, the kit looks plastic. I dont recommend it as you need one of the tubes to be permanently attached to the hoses (cause you need to cut heater hose). Plastic won't last long under conditions in the engine bay. After a while it will crack and leak.
If you really want to do a flush, you are better off removing the thermostat and circulate water thru the engine and drain it from the radiator. Do this several times, thats all you need.
why need to flush?
You need to flush your coolant once in a while to remove debris and what junk thats accumulated inside over the years.
Coolant additives will be used up over time so it has to be replaced as well.
Edited by Mona-vie
Yes, but the problem is there is no drain valve on the radiator on my car, troublesome to remove the pipe.
Just recently did a coolant flush at autobacs but think it is not clean.
They just suck out the old coolant and then pour in new coolant. Was told the vacuum suction enough to clean out at least 80%, better than draining.
So planning to do flushing myself with this kit. Prestone is well know brand, should last a long time.
Guess have to buy from amazon, cost usd 7.
Edited by Stanchiam
It can't be that troublesome to remove the hose right? its just a spring clamp or worm screw clamp
it is troublesome for mine as it is cramp and need to remove air filter etc to reach.
it is also not clean as not all will be flush out. Installing the kit will make it much easier and system will be flush clean.
anyway, less than $10, only problem now is not sure if it is sold in singapore.
if really cannot find, then order from amazon and ship from usa.
no drain valve? what is the model of your car? or u change it to aftermarket radiator?? there should be drain valve on every radiator, maybe its hidden at some corner that u cant see?
mine is chery QQ311, I have verify from forum it really do not have drain valve. aftermarket radiator cost how much??
that item cost less than $10 only
how can no drain valve? [laugh]
bro manual... read your manual....
OMG............. the VERY last bit of respect i had for china made cars....
gone right after i read your last post...
wah.. like that really cockup design leh... no drain valve how to maintain (replace coolant)???
Most engine blocks have a manually drain valve ocated along the water jacket. Shop will normally remove the lower radiator hose to try and drain the coolant.
Edited by Yeobh
I ever did engine flushing for my 5 years old Lancer once at a workshop. Cannot remember how much they charged me. Basically, they will drained my coolant in the radiator and add in some kind of liquid and let the engine run for few minutes. After that they drained it again and replaced it with a fresh coolant.
lol... thats what i thought
i went to autobacs and do coolant flush for $25(promo inclusive of coolant).
Ask them how they replace(before i told them my car make n mode),
they say their method is to suck out the old coolant using their machine and then add in new coolant.
They say they dont do draining method. lol...
They say this vacuum suction is modern method and is fast and better then draining. Say it is cleaner.
Maybe b-------t.
Anyway, they say this is how modern car is maintain.
Go to autobacs and try. ;)
Well, maybe this car is design for "modern" replacement method.
Pros is no coolant leaking, cons is have to go to autobacs.
Anyway, I am buying this kit and will do a flush myself in the future.
coolant just need to change once every few yrs...
Edited by Stanchiam
Coolant draining and replacement machines were in the market for more than 10 years in US and Japan. Nothing great, nothing new
