Kerwen 6th Gear January 24, 2011 Share January 24, 2011 I am just curious to know what is the small gear in front of the gearbox as in this link? [laugh] ↡ Advertisement Link to post Share on other sites More sharing options...
Youth92 2nd Gear January 24, 2011 Share January 24, 2011 I would like to find out too! Link to post Share on other sites More sharing options...
The_young_once Neutral Newbie January 24, 2011 Share January 24, 2011 I think it's a 4WD thing, to lock into "low range" gear or something, the setting used for extreme low speed torque for off-roading I think, afaik, maybe fellow 4WD enthusiasts can better explain it? Kenny Link to post Share on other sites More sharing options...
Mcf777 Turbocharged January 24, 2011 Share January 24, 2011 that should be the 4 X 4 gear. Just like SAF Land Rover with 2 gears. Link to post Share on other sites More sharing options...
Kish1313 Neutral Newbie January 24, 2011 Share January 24, 2011 yes right it's the 4x4 for off roads Link to post Share on other sites More sharing options...
Nonetheless Clutched January 24, 2011 Share January 24, 2011 I think it's a 4WD thing, to lock into "low range" gear or something, the setting used for extreme low speed torque for off-roading I think, afaik, maybe fellow 4WD enthusiasts can better explain it? Kenny Think you will see it in jeeps, Land rovers, it is to change the normal ratio of gears to smaller ratio, so that you can crawl when off road tight situation? Link to post Share on other sites More sharing options...
inlinesix Hypersonic January 24, 2011 Share January 24, 2011 Technically, it is transfer case shifter to lock in 2WD OR 4WD Link to post Share on other sites More sharing options...
Kerwen 6th Gear January 24, 2011 Author Share January 24, 2011 eh i have not driven before ... how do you engage these gears? switch when stationary or while moving no problem? ↡ Advertisement Link to post Share on other sites More sharing options...
All about smoking
All about smoking
Questions about Toyota Mark X
Jackie Chan about his Son, Money and Army.
Questions about Gearbox overhaul
Math Question
Math Question
All about springs and shocks(dampers)
Let's talk about NS... good memories or nightmares?
All about air filters...
