Devin Neutral Newbie February 5, 2011 Share February 5, 2011 hi guys! just bought a 2nd hand passo for a week. currently my brake pad worn out already. going to replace em once CNY is over. however other than the squealing sound i hear frm the pads, there's a growling noise from the left side wheel. rather loud and it sounds like the wheel bearings up lorry already. it's those metal rub metal noise however i don think is the wheel bearings as the sound comes only when driven a period and the disc got heated up and applying brakes. anyone got similar issues? [bigcry] Any got workshop to recommend for pad change tmr? i know a lot of work shop opens aft 7th feb. ↡ Advertisement Link to post Share on other sites More sharing options...
Rev2redline Neutral Newbie February 5, 2011 Share February 5, 2011 sounds like uneven rotors if the sound comes during hard braking... as for the brake pads, try to get them replaced asap.. a totally worn brake pad would result in the brake pad backing to be rubbing onto the rotor, causing the rotor to get worn prematurely.. also, most brakes have a metal clip on the brake pads that would give out a high pitch squeeling sound when you apply the brakes... check with your mechanic when you change your brake pads.. get his opinion on whether your discs require skimming if they could.. not sure if workshops are open during this festive season.. Link to post Share on other sites More sharing options...
Devin Neutral Newbie February 5, 2011 Author Share February 5, 2011 sounds like uneven rotors if the sound comes during hard braking... as for the brake pads, try to get them replaced asap.. a totally worn brake pad would result in the brake pad backing to be rubbing onto the rotor, causing the rotor to get worn prematurely.. also, most brakes have a metal clip on the brake pads that would give out a high pitch squeeling sound when you apply the brakes... check with your mechanic when you change your brake pads.. get his opinion on whether your discs require skimming if they could.. not sure if workshops are open during this festive season.. hard brake things seemed normal, its only when gradual or slow braking u start to hear the noise. but very random. it don happen everytime. sigh, most of the workshop opens aft 7, and the workshop i go opens aft 10. Link to post Share on other sites More sharing options...
Hermitage 1st Gear February 5, 2011 Share February 5, 2011 hi guys! just bought a 2nd hand passo for a week. currently my brake pad worn out already. going to replace em once CNY is over. however other than the squealing sound i hear frm the pads, there's a growling noise from the left side wheel. rather loud and it sounds like the wheel bearings up lorry already. it's those metal rub metal noise however i don think is the wheel bearings as the sound comes only when driven a period and the disc got heated up and applying brakes. anyone got similar issues? [bigcry] Any got workshop to recommend for pad change tmr? i know a lot of work shop opens aft 7th feb. Same thing happened to me. Thought it ws the bearings at first, but it turned out to be the worn brake pads. Mechanic advised not to drive as further braking could damage the entire brake system. But because my car is 26 years old, parts are hard to come by, they couldn't find the parts at short notice so had to wait till the next day. Lucky is was just before CNY. In the meantime, had to drive slow, with lots of engine braking when approaching junctions. Went back to the workshop the next day and they were kind enough to spend quite alot of time and effort to locate a set for me! Link to post Share on other sites More sharing options...
Keithchue 5th Gear February 5, 2011 Share February 5, 2011 mine got grrr noise, is the same sound that you are hearing Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear February 5, 2011 Share February 5, 2011 That was the worn brake pads trying to pronouce g-o-o-d instead of Happy Lunar New Year. Check if brake pads replacement overcome it Link to post Share on other sites More sharing options...
Devin Neutral Newbie February 6, 2011 Author Share February 6, 2011 the noise produce when i brake is er er er.. like metal rub metal lidat. and is rather loud. before pedal fully depress the sound drags abit like errrrrr errrrrrrrrr errrrrr .. fully depress no sound alr. but if those gradual braking right, when releasing pedal can hear orh orh orh.. like bearing worn out lidat. sians. :( Link to post Share on other sites More sharing options...
Renan Neutral Newbie February 6, 2011 Share February 6, 2011 I am driving a Toyota Vios 02 model. I have the same problems as you did. My car was bought with 16T mileage only and is roughly used. The thing is, when I am backing up, I am always hearing a squeaking sound. Is that the same as yours? How are your issues? ____________________________ fire magic outdoor grills ,swim spa Link to post Share on other sites More sharing options...
Tohdj Neutral Newbie February 6, 2011 Share February 6, 2011 when u step on the brakes....does the car vibrate more ...along with the growling sound? my front discs were sent for re-cut and i replaced the front brake pads. recut cost was S$50+ for both. Link to post Share on other sites More sharing options...
Redplanet Clutched February 6, 2011 Share February 6, 2011 the noise produce when i brake is er er er.. like metal rub metal lidat. and is rather loud. before pedal fully depress the sound drags abit like errrrrr errrrrrrrrr errrrrr .. fully depress no sound alr. but if those gradual braking right, when releasing pedal can hear orh orh orh.. like bearing worn out lidat. sians. :( Are your brake discs stock or aftermarket? The new pads you got, are they also OEM? Link to post Share on other sites More sharing options...
Devin Neutral Newbie February 9, 2011 Author Share February 9, 2011 Are your brake discs stock or aftermarket? The new pads you got, are they also OEM? i havent got the pads yet, this sat. erh. disc is stock. Link to post Share on other sites More sharing options...
Chuckhumprey Neutral Newbie February 15, 2011 Share February 15, 2011 hi guys! just bought a 2nd hand passo for a week. currently my brake pad worn out already. going to replace em once CNY is over. however other than the squealing sound i hear frm the pads, there's a growling noise from the left side wheel. rather loud and it sounds like the wheel bearings up lorry already. it's those metal rub metal noise however i don think is the wheel bearings as the sound comes only when driven a period and the disc got heated up and applying brakes. anyone got similar issues? [bigcry] Any got workshop to recommend for pad change tmr? i know a lot of work shop opens aft 7th feb. As per the squealing that I am also experiencing now. How could I know which of these 3 possible problems http://www.automd.com/diagnose/problems?aid=94 is the reason of the squealing noise from my brakes? Link to post Share on other sites More sharing options...
Fessm Clutched February 27, 2011 Share February 27, 2011 Hi all, I am also encountering squeaking sound when pressing brake while reversing into carpark lot. Mine is a 4 yr old Nissan Latio. Is it time to change my brake pads? Link to post Share on other sites More sharing options...
Stanchiam 1st Gear February 27, 2011 Share February 27, 2011 Hi all, I am also encountering squeaking sound when pressing brake while reversing into carpark lot. Mine is a 4 yr old Nissan Latio. Is it time to change my brake pads? squeaking mostly due to worn out brake pads, check it out fast, it not fix, the rotors will spoil and cost more to change Link to post Share on other sites More sharing options...
Happily1986 5th Gear February 27, 2011 Share February 27, 2011 I also encounter squeaking sound when depressing brake pedal initially. Please don't tell me it is the front brake pads. I just changed them during my last service and i am not even 5000 km away from that servicing interval since. Link to post Share on other sites More sharing options...
Stanchiam 1st Gear February 27, 2011 Share February 27, 2011 (edited) I also encounter squeaking sound when depressing brake pedal initially. Please don't tell me it is the front brake pads. I just changed them during my last service and i am not even 5000 km away from that servicing interval since. can be back too, if your back is not pad type, more troublesome to change. u can ask someone to stand beside your car while u brake to find out sound come from where Edited February 27, 2011 by Stanchiam Link to post Share on other sites More sharing options...
Happily1986 5th Gear February 27, 2011 Share February 27, 2011 can be back too, if your back is not pad type, more troublesome to change. u can ask someone to stand beside your car while u brake to find out sound come from where yea. could be. Come to think of it, i didn't change rear brake pads during that servicing. That squeaking came about after i had to do e brake after a moron decided to filter out of the expressway across the chevron markings. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear February 27, 2011 Share February 27, 2011 Same thing happened to me. Thought it ws the bearings at first, but it turned out to be the worn brake pads. Mechanic advised not to drive as further braking could damage the entire brake system. But because my car is 26 years old, parts are hard to come by, they couldn't find the parts at short notice so had to wait till the next day. Lucky is was just before CNY. In the meantime, had to drive slow, with lots of engine braking when approaching junctions. Went back to the workshop the next day and they were kind enough to spend quite alot of time and effort to locate a set for me! Not true. If metal rubs against metal. Replace rotor and brake pads. The entire brake system not damaged. That Mechanic a liar. Go to another Mechanic. ↡ Advertisement Link to post Share on other sites More sharing options...
Intermittent rattling noise, car in ICU
Steering rack noise on 2010 Altis
Extending quiet time by 1½ hours among recommendations to tackle neighbourhood noise in Singapore
Understanding Anti-lock Braking System (ABS)
NEA to lower vehicle noise levels from 2023
Brake squeak every morning
