Ronleo 6th Gear February 28, 2011 Share February 28, 2011 watever u get, dun buy TIBO! sure vomit blood... ↡ Advertisement Link to post Share on other sites More sharing options...
Khrz Neutral Newbie February 28, 2011 Share February 28, 2011 yeah tibo.. loading the initial gps position slow.. along the way sometime lag then miss a turn.. going to specific small road can make u go circle round and round.. ill say get a garmin or those apps for phone.. Link to post Share on other sites More sharing options...
Watwheels Supersonic March 1, 2011 Share March 1, 2011 (edited) Hows the routing and speed of the M8? I'm tempted to get the android version. The routing I find it ok but it does not able me to select roads to avoid like in Mapking. Re-routing speed is normal about 2~3 secs. Satellite lock is almost instant. Got the usual functions of a stand alone gps device like postal code search(subject to the quality of map) road search and POI search. POIs Nearby, Coordinates, trip record list etc. There's a pedestrian navigation mode too(have yet to try it out). I forgot to mention that it has a auto simulation mode like when you enter a tunnel eg KPE it will continue to run in simulation mode so that you can know which exit to head out. I feel that this is one of the good features to have in a gps navi. Voice setting has a lot of options, Mandarin, Hokkien, Hakka, English, Cantonese, Malay & Bahasa Indonesia. Edited March 1, 2011 by Watwheels Link to post Share on other sites More sharing options...
Zxcvb Turbocharged March 1, 2011 Share March 1, 2011 I'm using Papago M8 Pro. Navigate my trips up north many times. No problems at all. Got 3D function, junction view, POI search, postal code search, re-routing damn fast, sound is loud enough on a iPhone4. As for updated maps, they usually update the app (with updated maps of cos) periodically. Well, my advice is if you got iPhone, might as well make full use of it?? That's what the iPhone is made to do. It's like how many ppl who carries a iPhone also carries an iPod at the same time?? Link to post Share on other sites More sharing options...
Kangadrool Supersonic March 1, 2011 Share March 1, 2011 (edited) Garmin 1350 - signal loggin fast, re-calculation fast unlike 255W. But not as user friendly as many proclaimed to be. Searching can be a pain (slight spelling difference or too detailed input will return no find, plus, need to change to Malaysia map before can search.............) If only the user interface/searching can be as user friendly as Free Google map.... Edited March 1, 2011 by Kangadrool Link to post Share on other sites More sharing options...
Jman888 Moderator March 1, 2011 Share March 1, 2011 The routing I find it ok but it does not able me to select roads to avoid like in Mapking. Re-routing speed is normal about 2~3 secs. Satellite lock is almost instant. Got the usual functions of a stand alone gps device like postal code search(subject to the quality of map) road search and POI search. POIs Nearby, Coordinates, trip record list etc. There's a pedestrian navigation mode too(have yet to try it out). I forgot to mention that it has a auto simulation mode like when you enter a tunnel eg KPE it will continue to run in simulation mode so that you can know which exit to head out. I feel that this is one of the good features to have in a gps navi. Voice setting has a lot of options, Mandarin, Hokkien, Hakka, English, Cantonese, Malay & Bahasa Indonesia. for M8, there are options for normal, shortest distant and highway avoided, i only use the normal recommended and have not tried the other two options. Link to post Share on other sites More sharing options...
Knn Neutral Newbie March 1, 2011 Share March 1, 2011 4 mths old Shinco GPS selling $180.00 (NEG) Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear March 1, 2011 Share March 1, 2011 Can't answer this as I don't use the malaysian maps. However if comparing the Singapore ones then I think the sygic aura maps are better. Got alot more POI also. I find the interface alot easier to use as well. No worries then. Thanks though. I only use GPS when I'm in malaysia Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear March 1, 2011 Share March 1, 2011 The routing I find it ok but it does not able me to select roads to avoid like in Mapking. Re-routing speed is normal about 2~3 secs. Satellite lock is almost instant. Got the usual functions of a stand alone gps device like postal code search(subject to the quality of map) road search and POI search. POIs Nearby, Coordinates, trip record list etc. There's a pedestrian navigation mode too(have yet to try it out). I forgot to mention that it has a auto simulation mode like when you enter a tunnel eg KPE it will continue to run in simulation mode so that you can know which exit to head out. I feel that this is one of the good features to have in a gps navi. Voice setting has a lot of options, Mandarin, Hokkien, Hakka, English, Cantonese, Malay & Bahasa Indonesia. Thanks! Does it have the avoid tolls etc function? The rest sounds good, and with MFM I don't have to worry about outdated maps Link to post Share on other sites More sharing options...
Thargor 1st Gear March 1, 2011 Author Share March 1, 2011 Thanks bro for the good recommendations! I will probably get a Garmin...should I wait for the IT Show though? Thanks Watwheels for the good advice, I will check out the aps! Best Regards, Gavin Teo Link to post Share on other sites More sharing options...
Ronleo 6th Gear March 1, 2011 Share March 1, 2011 Thanks bro for the good recommendations! I will probably get a Garmin...should I wait for the IT Show though? Thanks Watwheels for the good advice, I will check out the aps! Best Regards, Gavin Teo buy from challenger. now got offer at $229 for garmin 1350 Link to post Share on other sites More sharing options...
Bartznrh Neutral Newbie March 30, 2011 Share March 30, 2011 I think you should try using Naviphone GPS (singapore) on your Iphone.. I been using it for quit some time now and i found it very good.. And user friendly.. Link to post Share on other sites More sharing options...
SCChia Neutral Newbie April 29, 2011 Share April 29, 2011 (edited) I got mine from COURTS and i will recommend it to bros & sis if they are looking for GPS. so far so good. But u know gps cant be 100% so ya Edited April 29, 2011 by SCChia ↡ Advertisement Link to post Share on other sites More sharing options...
Recommendation for Spectacles
Recommendation for gynaecologist
Speeding captured through on board GPS/In Car System
MyResponder app to call SCDF
Help with STA report remarks
