Workshop installed a not compatible coolant in my car
Nazuki
Hi all,
Need to check with you all it is ok for a workshop to install something not compatible for your car?
Had an accident last year Aug, went to insurance authorize workshop to have my car done and only recently found out they had installed a not compatible air-con coolant for me after i send my car for air-con servicing because of some sounds coming out from the car when i turn on the air-con.
Edited by Nazuki
Hi all,
Had an accident last year Aug, went to insurance autorise workshop to have my car done and only rencently found out they had installed a not compatible air-con coolant for me after i send my car for air-con servicing because of some sounds coming out from the car when i turn on the air-con.
After 7 months I think you will have trouble "proving" they were the ones that did it - UNLESS it is listed on your receipt what coolant they used and you still have the receipt.
ya that's what i think also, anyway had it fix by the air-con service workshop as it's damaging my air-con.
Just want to find out what can be done in case next time kana cheated by the stupid workshops in sg again
TS, how u know they install a different air-con coolant into ur car? u see them do during the servicing or u can tell the different between air-con coolant?
can u teach me how to differentiate... just for knowledge.
Aircon coolant should be correctly called refrigerant [usually mechanic call aircon gas].
What sort of noises when you turn on the aircon ? Analyse the type of noise would be helpful to determine possible problems.
May we enquire what this aircon service workshop did to resolve your aircon noises ?
you must be talking about the refirgerant?
R134 A who is the model that is used for cars nowadays...
Currently, got two source
one from china
one from Europe
Needless to say, which one is better..
but to save cost, most workshop uses China gas...
it contains more moisture and is less pure...
some of the more reputable brands...
Kalton (polar bear logo), or SSB....
Is air con compressor replaced. It could be wear n tear.
Moste insurance give 6. to 12 month warranty on accident repairs.
Aircon compressor also need compressor oil but a small amount.
Edited by 5936
ah.. is radiator sorry sorry... went to a car air-con workshop in jb cos recommended by fren. the boss saw the radiator straight away ask me if i kana accident before? then he told me the radiator is not original and is not cooling the gas and oil to the needed temperature and that causes noise coming out from the air-con motor. he did the normal servicing and insert a form between the radiator and the engine to prevent heat, then he ask me to monitor it for a week or so. if the sound still comes back then can say bye bye to the air-con motor, if get the radiator change asap.
