Change battery position
Bond38
Hi guys....
need to change to a bigger battery but compartment too small.
So will put battery in another place.
Anyone knw any wireman that can do the job?
Need to extent the wire longer to another side.
Thanks many many [wave]
relocating battery within the engine bay more an issue of the bracket than the cable... not easy to find...
if you're driving a front-heavy car (e.g. FF), want to balance it out for better handling, and don't mind taking up some space in the boot, you can consider moving the battery to the boot. Usually will require drilling 2 holes for the two posts, but you should not need to fabricate any brackets. Your battery should also last longer as it's not exposed to the heat in the engine bay.
For the cable, there's a shop at AMK Autopoint that sells. Not sure which one because it's my mechanic there who went upstairs to buy...
Try this shop
Autotronic Engrg
10 Ang Mo Kio Ind Pk 2A #03-02, Singapore, 568047
Or check with Eddie Chong hp:92723423
Edited by Yeobh
Thanks guys for yr advise :D
Actually....i got free flow of 2nd hand battery.
So if i can move the battery to another place,
I will save a lot.
Cheers
Hi guys....
The best place for battery is actually in the trunk. Cause the heat in the engine bay actualyl shorten the battery life.
Battery in trunk suffer from lack of air circulation ( heat built up). The long battery cable to the starter , over time will cause voltage drop due to copper wire aging.
