Bluefreud Clutched April 26, 2011 Share April 26, 2011 hi, does anyone know? im currently staying overseas, so do i need to vote? thanks, ↡ Advertisement Link to post Share on other sites More sharing options...
Yattokame 4th Gear April 26, 2011 Share April 26, 2011 hi, does anyone know? im currently staying overseas, so do i need to vote? thanks, You should need to, if the address you are registered with is under contest. Usually at embassy. Should you not turn up to vote, you will be struck off the register of voters -- however, you can ask for it to be reinstated for the next elections. Link to post Share on other sites More sharing options...
Shull Turbocharged April 26, 2011 Share April 26, 2011 You should need to, if the address you are registered with is under contest. Usually at embassy. Should you not turn up to vote, you will be struck off the register of voters -- however, you can ask for it to be reinstated for the next elections. Depends on where you are.. i think only if you stay in US or UK or HK then there is voting facilities in SG Embassy/High commision.. Link to post Share on other sites More sharing options...
Katz2282 1st Gear April 26, 2011 Share April 26, 2011 hi, does anyone know? im currently staying overseas, so do i need to vote? thanks, Nope, but you can choose to. ↡ Advertisement Link to post Share on other sites More sharing options...
Proton overseas
Proton overseas
MCF HangOut to Ishikawa. Here's how to rent a car in Japan.
AIRSIM overseas data SIM card discussion
All Overseas Calls To Start With “+” From 15 Apr, So You’ll Know When Overseas Scammers Are Calling
"Exporting" own car to overseas
Shopping done overseas may be subject to GST
Lesson Learnt for Overseas Car Hire
Lost passport overseas
