Luckcent 4th Gear September 19, 2011 Share September 19, 2011 Heard that in Malaysia, SGS2 already given 2.3.4 liao don't know true or not. ↡ Advertisement Link to post Share on other sites More sharing options...
Jman888 Moderator September 19, 2011 Share September 19, 2011 Heard that in Malaysia, SGS2 already given 2.3.4 liao don't know true or not. not much different mah, here we get 2.3.3... Link to post Share on other sites More sharing options...
Tigerwoods Turbocharged September 19, 2011 Share September 19, 2011 not much different mah, here we get 2.3.3... My LG P500 also upgraded to 2.3.3 - I regretted it because it takes up more memory and slowed the performance. The Apps Market takes longer to load, and using some apps also slower... I think Gingerbread 2.3 needs Min 1.0GHz to run... Link to post Share on other sites More sharing options...
Tigerwoods Turbocharged September 19, 2011 Share September 19, 2011 (edited) double post Edited September 19, 2011 by Tigerwoods Link to post Share on other sites More sharing options...
Happily1986 5th Gear September 19, 2011 Share September 19, 2011 yeah if i have shitload of apps running every now and then, i will agree with you. but the problem is, nothing is running and yet its slow like hell. and i am only running Office apps nia. basically, its just slow like s--t. even my 3GS running on IOS4 is much faster. than my Galaxy Tab How did you check? I noticed that when you check for running apps under Task Manager and when you check for running services under Settings, you see different things. I usually use the latter approach to kill apps of which their services are running. Link to post Share on other sites More sharing options...
Happily1986 5th Gear September 19, 2011 Share September 19, 2011 My LG P500 also upgraded to 2.3.3 - I regretted it because it takes up more memory and slowed the performance. The Apps Market takes longer to load, and using some apps also slower... I think Gingerbread 2.3 needs Min 1.0GHz to run... not true lah. Mine only running at 800Mhz, still quite zippy what. Link to post Share on other sites More sharing options...
Jman888 Moderator September 19, 2011 Share September 19, 2011 My LG P500 also upgraded to 2.3.3 - I regretted it because it takes up more memory and slowed the performance. The Apps Market takes longer to load, and using some apps also slower... I think Gingerbread 2.3 needs Min 1.0GHz to run... check on post #7 of http://www.mycarforum.com/index.php?showto...668941&st=0 Elfenstar recommend the latest market app, quite nice Link to post Share on other sites More sharing options...
Jman888 Moderator September 19, 2011 Share September 19, 2011 How did you check? I noticed that when you check for running apps under Task Manager and when you check for running services under Settings, you see different things. I usually use the latter approach to kill apps of which their services are running. i kill the active apps and clear memory (which will show more app running behind) Link to post Share on other sites More sharing options...
Joseph22 Turbocharged September 19, 2011 Share September 19, 2011 Heard that in Malaysia, SGS2 already given 2.3.4 liao don't know true or not. i go back and check my SGS2 tonight see what is the version. Link to post Share on other sites More sharing options...
Joseph22 Turbocharged September 19, 2011 Share September 19, 2011 How did you check? I noticed that when you check for running apps under Task Manager and when you check for running services under Settings, you see different things. I usually use the latter approach to kill apps of which their services are running. normally i do what Jman do. clear memonry and kill active apps.. tonight i go see the setting.. hope that is the reason.. the lack of smoothness is killing me after using my wife Ipad2 still hope for Tab 7.7 to hit the shore sometime next year May.. If i am not wrong, that is the only 7" tab with 3G enable. Link to post Share on other sites More sharing options...
Peaceracer 1st Gear November 16, 2011 Share November 16, 2011 Does anyone know, is it possible to surf e net via e mobile AP and take a call at e same time? Or is there any way that I do it? I m currently using galaxy s. Link to post Share on other sites More sharing options...
Jman888 Moderator November 16, 2011 Share November 16, 2011 Does anyone know, is it possible to surf e net via e mobile AP and take a call at e same time? Or is there any way that I do it? I m currently using galaxy s. you mean use the phone as hotspot? i guess should be able to. Link to post Share on other sites More sharing options...
Jim 1st Gear November 16, 2011 Share November 16, 2011 Does anyone know, is it possible to surf e net via e mobile AP and take a call at e same time? Or is there any way that I do it? I m currently using galaxy s. I have not done it for quite some time, but my rather old android phone can run as a hotspot and receive calls BUT once I am talking, the mobile data will stop. Drove me crazy when I was at customer site and I had to constantly choose between losing internet connection and making phone calls. Link to post Share on other sites More sharing options...
Pokyman 1st Gear November 17, 2011 Share November 17, 2011 Check with fellow S2 users .... i cant seem to play my mp3 via my car .. error msg was invalid device ... do i need to activate any thing inside my s2? Previously my iphone4 i could just plug in via the usb port and press the aux/usb button and my songlist will come out .... Link to post Share on other sites More sharing options...
Fresh7788 Neutral Newbie November 19, 2011 Share November 19, 2011 Everyone should just go ahead and get the Samsung Galaxy Note. It is awesome! Link to post Share on other sites More sharing options...
Sunburnsam 2nd Gear November 19, 2011 Share November 19, 2011 Everyone should just go ahead and get the Samsung Galaxy Note. It is awesome! Yeah I was so tempted to trade in my S2 for the NOTE. I will need to top in $450. Saw the screen and speed of the graphics....beautiful. But the size is quite big....definitely putting that thing in the pocket is errr......weird. Link to post Share on other sites More sharing options...
Shull Turbocharged November 19, 2011 Share November 19, 2011 Check with fellow S2 users .... i cant seem to play my mp3 via my car .. error msg was invalid device ... do i need to activate any thing inside my s2? Previously my iphone4 i could just plug in via the usb port and press the aux/usb button and my songlist will come out .... Your car reads mp3 files via USB? If yes, then you need to set your device as "USB Storage" mode (Settings>Wireless and Network>USB Utilities) first before plugging in the USB cable. ↡ Advertisement Link to post Share on other sites More sharing options...
Any Hokkien Song Lovers here?
Any regular casino slots player here?
Android Phones
Android Phones
How many here kena rape, attempted rape or molested?
Samsung and Huawei crush Apple's smartphone global share
Arsenal Fans Fall in here... SEDIA..
Anyone here follows "The Walking Dead"?
