Rg04 Neutral Newbie August 1, 2011 Share August 1, 2011 Alcantara is usually an expensive additional option for car seats/steering wheel/gear stick. However, one wonders how these can be maintained and cleaned properly, as there does not seem to be much literature or products out there on this topic. I have noticed how alcantara steering wheels/gear sticks tend to peel/flake after long usage, causing an uneven tone. If there are food stains etc, it will be easy to just wipe them off a leather seat, but I wonder what to do if the stains are on alcantara seats. Is there a specialist or someone out there who has a great technique on alcantara maintenance? Thanks in advance! ↡ Advertisement Link to post Share on other sites More sharing options...
5936 1st Gear August 1, 2011 Share August 1, 2011 try 3M scotchguard for protection Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear August 1, 2011 Share August 1, 2011 Alcantara is usually an expensive additional option for car seats/steering wheel/gear stick. However, one wonders how these can be maintained and cleaned properly, as there does not seem to be much literature or products out there on this topic. I have noticed how alcantara steering wheels/gear sticks tend to peel/flake after long usage, causing an uneven tone. If there are food stains etc, it will be easy to just wipe them off a leather seat, but I wonder what to do if the stains are on alcantara seats. Is there a specialist or someone out there who has a great technique on alcantara maintenance? Thanks in advance! Suede cleaners and protectors do the job. Link to post Share on other sites More sharing options...
Magfocus 5th Gear August 1, 2011 Share August 1, 2011 I believe there are alcantara cleaners for that, Sonax makes one Link to post Share on other sites More sharing options...
Kiadaw 6th Gear August 1, 2011 Share August 1, 2011 I believe there are alcantara cleaners for that, Sonax makes one Yap, you are right. If you make this thread a week earlier, I may give you the cleaner FOC. Too bad, pass to my friend liao. Link to post Share on other sites More sharing options...
Magfocus 5th Gear August 2, 2011 Share August 2, 2011 Yap, you are right. If you make this thread a week earlier, I may give you the cleaner FOC. Too bad, pass to my friend liao. I don't need one actually, my alcantara is covered.. TS is looking for one however. Thanks Link to post Share on other sites More sharing options...
Biohazard 1st Gear August 2, 2011 Share August 2, 2011 I used normal upholstery cleaners. Good enough for me. :) Link to post Share on other sites More sharing options...
Rg04 Neutral Newbie August 2, 2011 Author Share August 2, 2011 Hi, may I ask what you mean by "covered"? Do you tape up your alcantara with the 3M guard? Then, won't feel the texture of the alcantara already right? Kinda defeats the purpose to have alcantara option in the first place, doesn't it? Link to post Share on other sites More sharing options...
Rg04 Neutral Newbie August 2, 2011 Author Share August 2, 2011 Ha, thanks for the kind intentions anyway! But how do you use the cleaner? Spray onto the alcantara, then wipe dry? Won't this leave an uneven tone or cause peeling if you wipe too hard? Or just wet a cloth with the cleaner, then dab onto the alcantara surfaces? I'm just mindful about unnecessary rubbing the alcantara too hard, or causing uneven tone. Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic August 2, 2011 Share August 2, 2011 send for specialist la Link to post Share on other sites More sharing options...
Rg04 Neutral Newbie August 3, 2011 Author Share August 3, 2011 Is there one around? Would gladly send it to a specialist if there is one. Link to post Share on other sites More sharing options...
Ixat 1st Gear August 7, 2011 Share August 7, 2011 Car Pride does deep-extraction cleaning. I got quoted $250 for my Subaru. Decided to use Febreeze, spray till damp and wipe up with a cloth (lint free pls). Cloth turn black and seats smell good. http://www.carpride.com.sg/ Link to post Share on other sites More sharing options...
Eugn86 3rd Gear August 11, 2011 Share August 11, 2011 Use the Alcantara cleaning kit supplied, or use moist cloth and clean it. Bring it to professionals for cleaning once a year. Link to post Share on other sites More sharing options...
Skip Neutral Newbie August 25, 2011 Share August 25, 2011 (edited) Sonax alcantra cleaner is quite easy to use. It's a foamy solution (like gillette shaving foam), just apply it on the alcantra and wipe off with a clean dry cloth. The alcantra is very tough so you don't have to worry about peeling. Edited August 25, 2011 by Skip ↡ Advertisement Link to post Share on other sites More sharing options...
New Zealand - anyone?
Green fingers anyone?
