Wjhr 1st Gear August 12, 2011 Share August 12, 2011 http://www.obd-tuning.com.sg/ Isit worth doing to gain 15bhp 16nm for 890 dollars ???? ↡ Advertisement Link to post Share on other sites More sharing options...
Newkidontheblock Clutched August 12, 2011 Share August 12, 2011 what car are u driving may i ask? my answer to u is yes... better fuel consumption, better pickup, more power... all in all better drivability Link to post Share on other sites More sharing options...
Wjhr 1st Gear August 12, 2011 Author Share August 12, 2011 YF Sonata 2.4 MPI i checked with them, their only using dyno tested parameters (test car) changes for your engines. not doing ecu fuel remapping on dyno. from my experience, same engine doesn't mean they react the same way. what they do is plug out your ecu, remapped it, and put it back, do some testing done in 1 and half hour 890 dollar fly...... no dyno result, just telling you OH! you got 15bhp and 16 nm gain from your engine. "we tested already, and got those result (on the test car"Not your car")" btw the reason why i want to do this is that, i have change my exhaust system, air intake system. factory tune ecu runs rich for some reason. By doing this i assume they will adjusting my ignition timing to fully utilities my ron98 fuel i pump all the time to get better fuel consumption.(i am well aware of the pros and cons and risk involve of doing this) Overall, isit worth it to do a remap from their pre-programmed ecu map using dyno test parameters from their test car of your model. all they do it plug out, install, plug back in, do some diagnostic and BANG 890 dollar in 1 & half hr what car are u driving may i ask? my answer to u is yes... better fuel consumption, better pickup, more power... all in all better drivability Link to post Share on other sites More sharing options...
Sunburnsam 2nd Gear August 12, 2011 Share August 12, 2011 YF Sonata 2.4 MPI i checked with them, their only using dyno tested parameters (test car) changes for your engines. not doing ecu fuel remapping on dyno. from my experience, same engine doesn't mean they react the same way. what they do is plug out your ecu, remapped it, and put it back, do some testing done in 1 and half hour 890 dollar fly...... no dyno result, just telling you OH! you got 15bhp and 16 nm gain from your engine. "we tested already, and got those result (on the test car"Not your car")" btw the reason why i want to do this is that, i have change my exhaust system, air intake system. factory tune ecu runs rich for some reason. By doing this i assume they will adjusting my ignition timing to fully utilities my ron98 fuel i pump all the time to get better fuel consumption.(i am well aware of the pros and cons and risk involve of doing this) Overall, isit worth it to do a remap from their pre-programmed ecu map using dyno test parameters from their test car of your model. all they do it plug out, install, plug back in, do some diagnostic and BANG 890 dollar in 1 & half hr This came at the right ime....I am also interested in the tunning. But I have same reservation with you. Which is a better call? Re-tunning or Piggy Back. Re-tunning as above I also have the same question in the approach as listed above. Link to post Share on other sites More sharing options...
Newkidontheblock Clutched August 12, 2011 Share August 12, 2011 wow wjhr... i din know thats how it works! thanks for enlightening me... dont like the fact that they dont prove the performance increase to u... my friend tuned his golf gt sport... stage one... was an ECU reflash with Juzz4cars... damn his car after that really significantly got difference... Link to post Share on other sites More sharing options...
Wjhr 1st Gear August 12, 2011 Author Share August 12, 2011 This came at the right ime....I am also interested in the tunning. But I have same reservation with you. Which is a better call? Re-tunning or Piggy Back. Re-tunning as above I also have the same question in the approach as listed above. It's more of adjust the factory settings. no extra devices. i wont want a piggy back cause of this reason. (maybe wrong correct me if im wrong) The alternative to a proper remap is a plug-in tuning box(aka unichip, etc...). When comparing the two, a full remap is irrefutably the better option. A tuning box sends false sensor values throughout the complete rev-range. This tells the ECU that there is not enough fuel entering the engine. The ECU then over-fuels in order to gain performance. Although performance gains are made, they are at the cost of high emissions, higher engine temperatures, and general abuse of the engine. This may result in poor running, black smoke emitting from the exhaust, clogged injectors, rough idle, and engine cut-out. Bad tuning of a plug-in tuning will mass up your factory ecu. Stock factory ecu will adapt(relearn) overtime you have to do re-tuning again and again which cause a lot if were to find experience people to tune for you. Link to post Share on other sites More sharing options...
Minikong 1st Gear August 12, 2011 Share August 12, 2011 obd also tell me my car can get 50 more horse power just by tuning.. but i was like i want the 50 horse power for what... Link to post Share on other sites More sharing options...
Djdp Clutched August 12, 2011 Share August 12, 2011 get a proper tune using uni-chip better. be it rd or dyno tune Link to post Share on other sites More sharing options...
ER-3682 Supersonic August 12, 2011 Share August 12, 2011 I have done mine,using "Uprev" maps from the U.S.,for my "Z",not much power gain. Link to post Share on other sites More sharing options...
Satria_neo Clutched August 13, 2011 Share August 13, 2011 I would actually prelfer a piggyback or standalone ECU. This is because I prefer to leave the stock ECU untouched in case I need it for whatever reason (esp. important if car is under warranty). If ECU is flashed, it may reduce resale value if buyers do not like a modified ECU. Of course, piggyback or standalone, it should be plug and play with the harness so there is no need to cut wires. This will allow me to revert the car back to stock whenever I need it (just plug back original ECU). Of course, there are limitations with piggybacks. AFAIK, many piggybacks do not have VVTi adjustment and boost control. Only standalone ECUs have them. Link to post Share on other sites More sharing options...
Satria_neo Clutched August 13, 2011 Share August 13, 2011 http://www.obd-tuning.com.sg/ Isit worth doing to gain 15bhp 16nm for 890 dollars ???? Seriously, unless there is better FC, I wouldn't bother. Cause 15hp is very minimal. You can barely feel it. You may be able to feel the "power" for a short time. Then its back to square one again. Link to post Share on other sites More sharing options...
Minikong 1st Gear August 13, 2011 Share August 13, 2011 Seriously, unless there is better FC, I wouldn't bother. Cause 15hp is very minimal. You can barely feel it. You may be able to feel the "power" for a short time. Then its back to square one again. ya totally agree... it is all in 1 mind.... Link to post Share on other sites More sharing options...
Theoldjaffa Hypersonic August 13, 2011 Share August 13, 2011 TS, u can try harmony motor's ecu remap. full data logging. they are specialists in Korean cars. ↡ Advertisement Link to post Share on other sites More sharing options...
RS Chip Tuning
RS Chip Tuning
Piano - moving piano
Audi tuning by PA
Audi tuning by PA
DTE PedalBox for sale
Unichip Q
Unichip Q
Tuned Volvo D2
Tuned Volvo D2
DECAT AND TUNNING
DECAT AND TUNNING
