Vhtfhwlego Supercharged August 25, 2011 Share August 25, 2011 Just change my brake rotor and wondering whether need to redo the alignment? ↡ Advertisement Link to post Share on other sites More sharing options...
Forexter 2nd Gear August 25, 2011 Share August 25, 2011 No Need. Link to post Share on other sites More sharing options...
Kwchan 1st Gear August 25, 2011 Share August 25, 2011 how about changing of tire to a different profile? Link to post Share on other sites More sharing options...
Vhtfhwlego Supercharged August 25, 2011 Author Share August 25, 2011 There will not be a huge difference in alignment for different profile unless you track. Link to post Share on other sites More sharing options...
WFME Neutral Newbie August 25, 2011 Share August 25, 2011 Unless you going track or something, most of the time don't have to do alignment as the side slip is tested every 2 years (3 for new cars) during your inspection. You may want to check your alignment when you feel the steering is "pulling" towards one side by more than 5-10 degrees or when you have uneven tyre wear. ↡ Advertisement Link to post Share on other sites More sharing options...
Tool to change Spark Plug
Change Disc Rotors
Change Disc Rotors
X for twitter change request
