Neutralsg 5th Gear November 8, 2011 Share November 8, 2011 At last, I managed to put my jumpstart battery booster equipment to its actual use i.e. to start my weak car battery. My battery showed no sign of weakness since I left my car parked for 4 days until I tried to leave for a visitation yesterday - a public holiday. Suddenly, the car just refused to start. Since getting the jumpstart equipment more than a year ago, I tried to offer free jumpstart to anyone who needed such help when I was available but apparently no such opportunity arose. As a result of yesterday ↡ Advertisement Link to post Share on other sites More sharing options...
Neutralsg 5th Gear November 8, 2011 Author Share November 8, 2011 i know its not cheap,ard $180-$280.. I hope to get one around $150.00 if possible. Guess I have to scout around for another day before deciding if I must pay more than this. It seems AA sells Amaron brand for $175.00 to members and probably with additional 6 months warranty. Link to post Share on other sites More sharing options...
Neutralsg 5th Gear November 8, 2011 Author Share November 8, 2011 new batt in car should not be needing this batt booster even u park your car for 4 days.. last year i park my sunny when i go holiday for 6 days & still got no problem to start it.. how many 4 days u plan to park a mth? save the money for others accessories,dont waste for something to store up your boot.. My battery is 2 years 11 months. Battery due for a change since it's now weak. Equipment had been useful. At least to me. Link to post Share on other sites More sharing options...
SimonTan 2nd Gear November 8, 2011 Share November 8, 2011 How much is the booster pack? How long can the booster pack last? Some may say a save in time is priceless. Indeed for those with time constraints....booster pack is the best option! Link to post Share on other sites More sharing options...
Neutralsg 5th Gear November 8, 2011 Author Share November 8, 2011 How much is the booster pack? How long can the booster pack last? Some may say a save in time is priceless. Indeed for those with time constraints....booster pack is the best option! It cost $115 and $139 for the different models. Just google Jumpstart Battery Booster. The shop is relocating to @Central and should be operating from 15 Nov onwards. They are moving from Chinatown Point. Link to post Share on other sites More sharing options...
Jefkking Clutched November 8, 2011 Share November 8, 2011 Hi, what model battery ? 55D23L / R ? Link to post Share on other sites More sharing options...
Jefkking Clutched November 8, 2011 Share November 8, 2011 Hi, what was your car battery model ? 55D23L / R ? Link to post Share on other sites More sharing options...
Neutralsg 5th Gear November 8, 2011 Author Share November 8, 2011 hello,pls reply to TS & ask him,i didn't use so i don't know.. I think Jeffking is asking about your battery. Mine is 70D/23L. Link to post Share on other sites More sharing options...
Neutralsg 5th Gear November 8, 2011 Author Share November 8, 2011 Hi, what was your car battery model ? 55D23L / R ? 70D/23L Varta. Link to post Share on other sites More sharing options...
Kb27 Supersonic November 8, 2011 Share November 8, 2011 70D is better than 55D rite? Generally, not true. Each manufacturer has their own way of numbering. To compare apple to apple, you need to check AH and CCA...the higher the better. Link to post Share on other sites More sharing options...
Jefkking Clutched November 8, 2011 Share November 8, 2011 Made in Indonesia NOT Germany ! Link to post Share on other sites More sharing options...
Jefkking Clutched November 8, 2011 Share November 8, 2011 (edited) Now newest mdoels should be 75D23L of 65Ah with CCA 580 Ampere. Edited November 8, 2011 by Jefkking Link to post Share on other sites More sharing options...
Kb27 Supersonic November 8, 2011 Share November 8, 2011 normally the AH & CCA come in which number as normal & up till which number is superb.. It depends on the overall battery physical size. The D23L has about 23 cm length. It has to accommodate 6 cells. Each cell is then limited to about maybe 3 cm (?) of space. So, how many lead plates can be stuffed into the 3 cm of space will determine the total CCA and AH. The more the merrier, but there's a size restriction. Now, if you go to a bigger battery like D26L, you have more space internally to stuff more lead plates. Thus the potential is there to go even higher CCA and AH. But of coz, the cheapo battery can just be built "big" on the outside, but put lesser number of plates on the inside. So it's possible that some D23L that can have higher CCA/AH than a D26L. Link to post Share on other sites More sharing options...
Neutralsg 5th Gear November 8, 2011 Author Share November 8, 2011 Made in Indonesia NOT Germany ! Can you clarify what you are trying to drive at Link to post Share on other sites More sharing options...
Jefkking Clutched November 8, 2011 Share November 8, 2011 Go for 75D23L that fit your battery compartment of which was 23 cm in length (Same size as your existing 70D23L BUT you can't go for "D26L"). Link to post Share on other sites More sharing options...
Kb27 Supersonic November 8, 2011 Share November 8, 2011 so like that how to check which is good to buy for my lau po car? If your battery tray is limited to 23cm length, then you can only stick with D23L battery. Find the biggest AH and CCA in that size. Most manufacturers have 2 versions, example 60AH and 70AH or 65AH and 75AH, etc. ↡ Advertisement Link to post Share on other sites More sharing options...
Battery for Honda Vezel
My EV journey to the i4
Let's talk about Vaccine Booster Shots
