Tigershark1976 Turbocharged November 9, 2011 Share November 9, 2011 Found that my exhaust pipe is rusty and tried to clean it up and sprayed with some high temp paint (the one with a barbeque pit on the can) but it doesnt even last for 3 mth...Im currently trying source some other brand so that I could re-do the painting again on my exhauxt pipe... any recomendation? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Sorrow 2nd Gear November 9, 2011 Share November 9, 2011 Found that my exhaust pipe is rusty and tried to clean it up and sprayed with some high temp paint (the one with a barbeque pit on the can) but it doesnt even last for 3 mth... Im currently trying source some other brand so that I could re-do the painting again on my exhauxt pipe... any recomendation? I bought from HomeFix before but think limited colours, can try there 1 Link to post Share on other sites More sharing options...
Ken4555 1st Gear November 9, 2011 Share November 9, 2011 (edited) last i saw at macwell have... try autobacs? Edited November 9, 2011 by Ken4555 1 Link to post Share on other sites More sharing options...
Ken4555 1st Gear November 9, 2011 Share November 9, 2011 i bought before at Johnson there... VHT on the can one... spray my chamber exhaust pipe for my RXZ... lol different from those hopless high temp paint in most hardware shops... Link to post Share on other sites More sharing options...
Oregon 1st Gear November 9, 2011 Share November 9, 2011 I think maybe your problem could be due to non sticking of the paint due to the rust. When you say exhaust does this mean manifold or the lower end pipes? When the rust cancer strikes it starts from beneath the paint so the paint will keep falling off unless you get rid of the rust. 1 Link to post Share on other sites More sharing options...
Satria_neo Clutched November 10, 2011 Share November 10, 2011 DEI Hi Temp paint. I saw it at Stamford tyres 1 Link to post Share on other sites More sharing options...
K3037 Neutral Newbie November 10, 2011 Share November 10, 2011 I bought from HomeFix before but think limited colours, can try there Yes, I saw it there also, some other hardware shops and very limited colours to choose. 1 Link to post Share on other sites More sharing options...
LoverofCar 6th Gear November 19, 2011 Share November 19, 2011 (edited) Are you referring to the muffler tip? I had this problem too. Tried all sort of high temp paint cannot cure the rust. Ended up, went to man exhaust and had it removed by torch and welded a super nice tip.....no regrets...Once it rusted, very hard to treat it ....is like cancer....so have it remove before it spread deeper into the muffler Edited November 19, 2011 by LoverofCar 1 Link to post Share on other sites More sharing options...
Happily1986 5th Gear November 19, 2011 Share November 19, 2011 I am not saying this will help prevent further rusting for sure but if you want to ensure that your paint sticks, you need to use a metallic paint primer first. 1 Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear November 19, 2011 Share November 19, 2011 Can check if some paint shops have it. 1 Link to post Share on other sites More sharing options...
5936 1st Gear November 20, 2011 Share November 20, 2011 Industrial grade high temp coating. Such as Jotatemp650. Sorry dont sell in spray can. Need brush or roller to achieve thickness . call Jotun office, they will entertain even for 1 can. 1 Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged November 20, 2011 Author Share November 20, 2011 (edited) Industrial grade high temp coating. Such as Jotatemp650. Sorry dont sell in spray can. Need brush or roller to achieve thickness . call Jotun office, they will entertain even for 1 can. really??!! thanks for the info bro! Edited November 20, 2011 by Tigershark1976 1 Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged November 20, 2011 Author Share November 20, 2011 Are you referring to the muffler tip? I had this problem too. Tried all sort of high temp paint cannot cure the rust. Ended up, went to man exhaust and had it removed by torch and welded a super nice tip.....no regrets...Once it rusted, very hard to treat it ....is like cancer....so have it remove before it spread deeper into the muffler my muffler tip its still okie, its the midpipe itself that rusted... Link to post Share on other sites More sharing options...
Carbine- Clutched November 21, 2011 Share November 21, 2011 What is best for my car? lowering springs or coil-overs? i want to drop my car but i don't want to spend to much money so i want to buy lowering springs but i heard its not safe for my shocks is it true or not, i want to buy tein lowering springs. dude...off topic lei... get coilovers if u can la, performance better, height adjustable... 1 Link to post Share on other sites More sharing options...
AlvinDj 1st Gear November 22, 2011 Share November 22, 2011 Where else exactly sells VHT paint.. ? Was thinking of using it for my calipers... 1 Link to post Share on other sites More sharing options...
Thedream 3rd Gear November 23, 2011 Share November 23, 2011 shop named "Kim Able" at Jurong Pt basement sells ~$10 spray cans. I think only silver and black. Maybe white... 1 Link to post Share on other sites More sharing options...
Escksu Clutched November 25, 2011 Share November 25, 2011 I saw this high temp DEI coating at autobacs. 1 Link to post Share on other sites More sharing options...
Sbu7360 1st Gear February 3, 2012 Share February 3, 2012 bought tis at self fix $16 per can ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Wheel Spacer, where to buy?
Are You A Big Spender For A High End Bed Mattress?
Get Quality Spray Paint & Car Body Work Repair Services at Affordable Price @ Divine Splash today!
Where you cut your hair?
NBA - Where Amazing Happens
