Toyota Wish PCD
Cichildae
Hi all,
Like to enquire what is the pcd for toyota wish? Looking for stock rims of 16" 5 x 100 pcd and heard that the toyota wish pcd is also 5x100...
Thanks for reading!
Hi all,
Thanks for reading!
yes it is 5x100. you are on the right track
Hi all,
Thanks for reading!
if the stock rim u found is from another wish, 100% can fix your car.
but another set of stock rim 5x100 pcd , from another car, like subaru, might not fix your car properly,
( i not sure also )
u better test b4 u buy. check the diameter of the rim hub. if its bigger then your wish. it can fix, u just need to install centre bore ring to fill up the gap.
and test the offset also . make sure its not too small, it might hit your brake cab, or other places.
and lastly better ask tyre shop balance the rims for u, check physically with your own eyes, the rim is not worbbering.
Stock rims from subaru should be able to fit easily on the Wish. Most of the subaru rims except for the STI are 5 x 100 pcd with a positive offset in the 50s.
yes su ba lu is also 5 x 100 but the subalu centre hole is Bigger :D (56.1mm) over the wish 54.1mm center diameter
is always best your rim is sitting centre fit
