Billcoke 2nd Gear December 3, 2011 Share December 3, 2011 Any bros here has problem downloading the PS3 OS 4.0 via the console? mine has been downloading for the past 30mins, and it is still suck at 1%. ↡ Advertisement Link to post Share on other sites More sharing options...
Shorty Turbocharged December 3, 2011 Share December 3, 2011 Mine no prob. Already updated few days back. Link to post Share on other sites More sharing options...
Wreckwrx 1st Gear December 3, 2011 Share December 3, 2011 Nope..... I updated on Tues afternoon...... took me ard 30mins....... via wifi....... Link to post Share on other sites More sharing options...
Billcoke 2nd Gear December 3, 2011 Author Share December 3, 2011 Nope..... I updated on Tues afternoon...... took me ard 30mins....... via wifi....... mine is still dead, the TV is now blank, can't see the status, not sure whether to turn off the power, but worry that it may corrupt the OS too. What should I do? Link to post Share on other sites More sharing options...
Wreckwrx 1st Gear December 3, 2011 Share December 3, 2011 mine is still dead, the TV is now blank, can't see the status, not sure whether to turn off the power, but worry that it may corrupt the OS too. What should I do? Your 1% is dl rate of installation rate? If it is halfway dl then went dead.... then can reboot w/o affecting the OS...... If it is installation halfway and then went dead...... this one really good luck to u.... Link to post Share on other sites More sharing options...
Billcoke 2nd Gear December 4, 2011 Author Share December 4, 2011 Your 1% is dl rate of installation rate? If it is halfway dl then went dead.... then can reboot w/o affecting the OS...... If it is installation halfway and then went dead...... this one really good luck to u.... the 1% is during DL. I did a PC installation instead, it solved the problem. Link to post Share on other sites More sharing options...
Wreckwrx 1st Gear December 4, 2011 Share December 4, 2011 Good to know your problems solved. Cheers!! Wat games u play? Link to post Share on other sites More sharing options...
Billcoke 2nd Gear December 4, 2011 Author Share December 4, 2011 Good to know your problems solved. Cheers!! Wat games u play? Sorry, the problem is back again. After the OS4 upgrade, the console takes a long time to boot up, and when shutdown, there is a 3 beeps. I've a bad feeling the HDD is corrupted. I'm playing GT5. Link to post Share on other sites More sharing options...
Angguguay Neutral Newbie December 5, 2011 Share December 5, 2011 Sorry, the problem is back again. After the OS4 upgrade, the console takes a long time to boot up, and when shutdown, there is a 3 beeps. I've a bad feeling the HDD is corrupted. I'm playing GT5. I also experienced this 3 beeps before, but it's not during any OS upgrade. whenever my PS3 hung during a gameplay, everything freezes and I could not even shut the PS3 down using my controller (pressing the PS button). the only option is to press the POWER button, which will give a 3 beep when I do so. I read somewhere before, 3 beeps usually happens when the PS3 is being shutdown with some program still running in the background, which is the "hanging" game in my case. mine is the slim set. Link to post Share on other sites More sharing options...
Unltd 5th Gear December 5, 2011 Share December 5, 2011 I also experienced this 3 beeps before, but it's not during any OS upgrade. whenever my PS3 hung during a gameplay, everything freezes and I could not even shut the PS3 down using my controller (pressing the PS button). the only option is to press the POWER button, which will give a 3 beep when I do so. I read somewhere before, 3 beeps usually happens when the PS3 is being shutdown with some program still running in the background, which is the "hanging" game in my case. mine is the slim set. Yup, 3 beeps is forced shutdown due to system hang. When this happens very often, usually YLOD coming..... Link to post Share on other sites More sharing options...
Billcoke 2nd Gear December 5, 2011 Author Share December 5, 2011 Yup, 3 beeps is forced shutdown due to system hang. When this happens very often, usually YLOD coming..... I've that bad feeling too, luckily it is still under warranty. Link to post Share on other sites More sharing options...
Billcoke 2nd Gear December 5, 2011 Author Share December 5, 2011 I also experienced this 3 beeps before, but it's not during any OS upgrade. whenever my PS3 hung during a gameplay, everything freezes and I could not even shut the PS3 down using my controller (pressing the PS button). the only option is to press the POWER button, which will give a 3 beep when I do so. I read somewhere before, 3 beeps usually happens when the PS3 is being shutdown with some program still running in the background, which is the "hanging" game in my case. mine is the slim set. Yeah, the 3 beeps means that the system is busy in the background and hung, which is not a good sign. I did file system restore, it didn't work. Going to send Sony for repair. Link to post Share on other sites More sharing options...
Unltd 5th Gear December 5, 2011 Share December 5, 2011 Yeah, the 3 beeps means that the system is busy in the background and hung, which is not a good sign. I did file system restore, it didn't work. Going to send Sony for repair. You better get it repaired properly during warranty. Do note to leave the PS3 in an open space and make sure it is a few inches away from everything so heat does not build up, especially the sides and the back of the PS3. Link to post Share on other sites More sharing options...
Angguguay Neutral Newbie December 5, 2011 Share December 5, 2011 Yeah, the 3 beeps means that the system is busy in the background and hung, which is not a good sign. I did file system restore, it didn't work. Going to send Sony for repair. that sounds bad. good thing that u still hv warranty. if u get the chance, pls update us again when u got it back frm Sony. something just for my personal interest only, to see how long it takes for Sony to repair, and how much is it if u dun mind sharing. thx bro. Link to post Share on other sites More sharing options...
Billcoke 2nd Gear December 13, 2011 Author Share December 13, 2011 that sounds bad. good thing that u still hv warranty. if u get the chance, pls update us again when u got it back frm Sony. something just for my personal interest only, to see how long it takes for Sony to repair, and how much is it if u dun mind sharing. thx bro. The Father&Mother board is spoilt. Repair is FOC, need 7 days to repair. Link to post Share on other sites More sharing options...
Fireball0088 5th Gear December 13, 2011 Share December 13, 2011 Sorry, the problem is back again. After the OS4 upgrade, the console takes a long time to boot up, and when shutdown, there is a 3 beeps. I've a bad feeling the HDD is corrupted. I'm playing GT5. three beeps? i think your console is dying already Link to post Share on other sites More sharing options...
Fireball0088 5th Gear December 13, 2011 Share December 13, 2011 I've that bad feeling too, luckily it is still under warranty. could be lemon set or not enough cooling Link to post Share on other sites More sharing options...
Fireball0088 5th Gear December 13, 2011 Share December 13, 2011 The Father&Mother board is spoilt. Repair is FOC, need 7 days to repair. good to hear that it is still under warranty. i would advice you to test it out when it is back. make sure you play it to the max to ensure that it is repaired properly. btw, what games do you play? ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
Singpost courier dishonesty with incredibly lousy service
