Rogersk8ter 1st Gear December 17, 2011 Share December 17, 2011 Ive abt 3 L of Dia Queen SP 3 ATF left. My power steering fluid looks dark. Thinking of using the remainder ATF for power steering fluid. Searched thru the web and found the Dai Queen SP3 has a higher spec than the recommended Daxron 3 for power steering listed in my car manual. The Dai Queen ATF has cleaning additive and higher temperature range compared to Daxron 3. The Daxron 3 is pretty old spec and basically a low spec hydraulic fluid w/o additives. In this respect, would u think its better to use the remaider Dai Queen SP3 to replace my old existing power fluid? There were mech who would do it while some will caution against such practice. Anyone any experience or advice? ↡ Advertisement Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear December 17, 2011 Share December 17, 2011 I like to believe it will outlast your car balance COE Link to post Share on other sites More sharing options...
Trex101 3rd Gear December 17, 2011 Share December 17, 2011 Not true that SP III has higher spec than Dexron III, just different fluid friction properties. But yes, you can use your SP III for your PSF, no problem. Link to post Share on other sites More sharing options...
5936 1st Gear December 18, 2011 Share December 18, 2011 ATF 3 is good enough for power steering. ↡ Advertisement Link to post Share on other sites More sharing options...
Steering leather wrapping
Porsche’s First Steer-By-Wire System Is Designed For Less Feedback, Not More
Home power back up
Home power back up
Steering column
Steering column
Honda Stream 2009 No Power and High fuel Consumption
Alcades power optimizer
