Usamomo Neutral Newbie February 3, 2012 Share February 3, 2012 Recently my car have been giving me some problem. When driving during high speed, there will have this "gong gong gong" sound coming from the front. The noise is most obvious during downslope when I release the gas pedal (no engine noise) Gong sound comes in around 70km/h I have went to few workshops and all can't pinpoint the problem. Since then I have change front absorber, front wheel bearings, tyres, do servicing. Today also check drive shaft not this problem. Anyone got good workshop to recommend? Greatly appreciated. ↡ Advertisement Link to post Share on other sites More sharing options...
Gasguzzler 1st Gear February 3, 2012 Share February 3, 2012 Go back to your authorised service centre. Link to post Share on other sites More sharing options...
Usamomo Neutral Newbie February 3, 2012 Author Share February 3, 2012 Mine is parallel import, 5 yrs old car Link to post Share on other sites More sharing options...
Gasguzzler 1st Gear February 3, 2012 Share February 3, 2012 (edited) What is your car make? It is likely a suspension problem. Check your front anti-roll bar linkages and lower control arms. Given the sound only happens when the front end is depressed (high speed and slowing down) Edited February 3, 2012 by Gasguzzler Link to post Share on other sites More sharing options...
Mits_jc 5th Gear February 3, 2012 Share February 3, 2012 Piggyback on this thread I am driving a 5 yr old Honda Jazz, CVT. While decelerating from 80kmh have this high pitched wheeee sound all the way till it reaches 60kmh. Never do any ICE, so it's not the "aeroplane" sound faced by pple who upgrade their ICE. Delerelating from 100kmh don't have this sound. The sound only comes out when gas pedal is released AND slowing down from 80kmh to 60kmh and below 60kmh this wheeee sound stops. Link to post Share on other sites More sharing options...
Gasguzzler 1st Gear February 3, 2012 Share February 3, 2012 Piggyback on this thread I am driving a 5 yr old Honda Jazz, CVT. While decelerating from 80kmh have this high pitched wheeee sound all the way till it reaches 60kmh. Never do any ICE, so it's not the "aeroplane" sound faced by pple who upgrade their ICE. Delerelating from 100kmh don't have this sound. The sound only comes out when gas pedal is released AND slowing down from 80kmh to 60kmh and below 60kmh this wheeee sound stops. Can be due to many things. U need to narrow down the possibilities. Link to post Share on other sites More sharing options...
Usamomo Neutral Newbie February 3, 2012 Author Share February 3, 2012 Piggyback on this thread I am driving a 5 yr old Honda Jazz, CVT. While decelerating from 80kmh have this high pitched wheeee sound all the way till it reaches 60kmh. Never do any ICE, so it's not the "aeroplane" sound faced by pple who upgrade their ICE. Delerelating from 100kmh don't have this sound. The sound only comes out when gas pedal is released AND slowing down from 80kmh to 60kmh and below 60kmh this wheeee sound stops. Mine used to have hissing sound during high speed, above 90km. After change mine wheel bearing the sound disappear. But like what gasguzzler mentioned, it might be due to many things. For a start, Try turning off aircon to test. Link to post Share on other sites More sharing options...
Usamomo Neutral Newbie February 3, 2012 Author Share February 3, 2012 What is your car make? It is likely a suspension problem. Check your front anti-roll bar linkages and lower control arms. Given the sound only happens when the front end is depressed (high speed and slowing down) Mine is Toyota rush Link to post Share on other sites More sharing options...
TamChiak101 Neutral Newbie February 3, 2012 Share February 3, 2012 ya go back for maintenance servicing Link to post Share on other sites More sharing options...
Elmo 4th Gear February 3, 2012 Share February 3, 2012 Recently my car have been giving me some problem. When driving during high speed, there will have this "gong gong gong" sound coming from the front. The noise is most obvious during downslope when I release the gas pedal (no engine noise) Gong sound comes in around 70km/h I have went to few workshops and all can't pinpoint the problem. Since then I have change front absorber, front wheel bearings, tyres, do servicing. Today also check drive shaft not this problem. Anyone got good workshop to recommend? Greatly appreciated. You can try rotating and re-balancing your tyres. An unbalanced tyre can cause the 'Wong x infinity' sound but usually it should be increasing in frequency as the speed increases. No harm trying since it should be about $15 to $20 only. Link to post Share on other sites More sharing options...
Ernesttan664 Neutral Newbie February 3, 2012 Share February 3, 2012 having same problem with my car as well :angry: Link to post Share on other sites More sharing options...
Chickensoup 1st Gear February 3, 2012 Share February 3, 2012 Recently my car have been giving me some problem. When driving during high speed, there will have this "gong gong gong" sound coming from the front. The noise is most obvious during downslope when I release the gas pedal (no engine noise) Gong sound comes in around 70km/h I have went to few workshops and all can't pinpoint the problem. Since then I have change front absorber, front wheel bearings, tyres, do servicing. Today also check drive shaft not this problem. Anyone got good workshop to recommend? Greatly appreciated. take a look at your engine mounting Link to post Share on other sites More sharing options...
Jackieli85 Neutral Newbie February 9, 2012 Share February 9, 2012 Mine too getting more noisy :( Link to post Share on other sites More sharing options...
Sitilee84 Neutral Newbie February 9, 2012 Share February 9, 2012 anyone try the sound block at the tire area ? Link to post Share on other sites More sharing options...
Cephas 3rd Gear February 10, 2012 Share February 10, 2012 gong gong or wong wong? Maybe wheel bearing kaput... Link to post Share on other sites More sharing options...
Jchuacl Clutched February 10, 2012 Share February 10, 2012 It does sounds like your fan motor could be spoilt or going to spoil considering that you have changed bearings and tyres. Check out Ricardo cars, they are pretty experienced with PI Toyotas. Recently my car have been giving me some problem. When driving during high speed, there will have this "gong gong gong" sound coming from the front. The noise is most obvious during downslope when I release the gas pedal (no engine noise) Gong sound comes in around 70km/h I have went to few workshops and all can't pinpoint the problem. Since then I have change front absorber, front wheel bearings, tyres, do servicing Today also check drive shaft not this problem. Anyone got good workshop to recommend? Greatly appreciated. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear February 10, 2012 Share February 10, 2012 Previous used ccent I bought came with light gauage/weight steel wheels (about 3mm thick). I suspected that at higher speed, the wheel flexes and gave me funny sound. I swapped them for thicker gauge wheels (about 4mm thick) and the problem was gone. Could that be also your problem? Can check if the wheels are of lighter gauge/thickness than others? Link to post Share on other sites More sharing options...
Flashlive Neutral Newbie March 22, 2012 Share March 22, 2012 You can have a code scanner and read the code ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding – Jun 2026
Car Curtains/Sunshades
Lower your car interior temp when parking in the hot SUN
How to get car financing loan?
Car wash at JB
Car wash at JB
