Cybertech 4th Gear February 23, 2012 Share February 23, 2012 Time to change tyres, this time round thinking of changing to either higher or lower profile on stock ralliart rims with 195/60/15 tyres currently. Am I correct to say these: 1) Change to 195/65/15 and the gap between tyres and wheel arc will be lesser BUT car become taller. 2) Change to 195/55/15 and the gap between tyres and wheel arc will become larger BUT car will be lower. Yet to decide 1) or 2) but for 2) when side view I can imagine it might look like the car on a set of small wheel. To have a comfort ride, 1) or 2) will be a better choice? ↡ Advertisement Link to post Share on other sites More sharing options...
Nf0rc3r 1st Gear February 23, 2012 Share February 23, 2012 This is what I use http://www.miata.net/garage/tirecalc.html The thicker the tyre sidewall the more comfortable it will be.. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear February 23, 2012 Share February 23, 2012 Time to change tyres, this time round thinking of changing to either higher or lower profile on stock ralliart rims with 195/60/15 tyres currently. Am I correct to say these: 1) Change to 195/65/15 and the gap between tyres and wheel arc will be lesser BUT car become taller. 2) Change to 195/55/15 and the gap between tyres and wheel arc will become larger BUT car will be lower. Yet to decide 1) or 2) but for 2) when side view I can imagine it might look like the car on a set of small wheel. To have a comfort ride, 1) or 2) will be a better choice? No mention car model, car weight, whats wrong with current tire size. I believe we know too little to share more helpful/useful ideas, if any. Link to post Share on other sites More sharing options...
Yuan 6th Gear February 24, 2012 Share February 24, 2012 Time to change tyres, this time round thinking of changing to either higher or lower profile on stock ralliart rims with 195/60/15 tyres currently. Am I correct to say these: 1) Change to 195/65/15 and the gap between tyres and wheel arc will be lesser BUT car become taller. 2) Change to 195/55/15 and the gap between tyres and wheel arc will become larger BUT car will be lower. Yet to decide 1) or 2) but for 2) when side view I can imagine it might look like the car on a set of small wheel. To have a comfort ride, 1) or 2) will be a better choice? With (1) or (2), please do take into consideration of the deviation or variation in the accuracy of your speedometer. A tire calculator may help you in this case. Link to post Share on other sites More sharing options...
Cybertech 4th Gear February 24, 2012 Author Share February 24, 2012 No mention car model, car weight, whats wrong with current tire size. I believe we know too little to share more helpful/useful ideas, if any. Actually nothing wrong with the current size lah. Car was Lancer CS3, since changing tyres just want to try out another sizes whether to slightly lower the ride with 55 profile or reduce the gap between tyre and wheel arc using 65 profile. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear February 24, 2012 Share February 24, 2012 Actually nothing wrong with the current size lah. Car was Lancer CS3, since changing tyres just want to try out another sizes whether to slightly lower the ride with 55 profile or reduce the gap between tyre and wheel arc using 65 profile. I believe this model to be a little slippery, so not advisable to try learn through mistake(s). Stick to stock tire or slightly narrower ones. Avoid changing the tire profile. Link to post Share on other sites More sharing options...
Eddielawson 1st Gear February 24, 2012 Share February 24, 2012 If you choose 65 profile, you might encounter tire rubbing fender when turning. Link to post Share on other sites More sharing options...
Deckbuild 6th Gear February 25, 2012 Share February 25, 2012 For your case, changing from 60 to 65 don't cause much difference, speedo might read slower that's all. Definitely car will be slightly taller. Lower the profile will give you a harsher ride. Link to post Share on other sites More sharing options...
Cybertech 4th Gear February 25, 2012 Author Share February 25, 2012 I believe this model to be a little slippery, so not advisable to try learn through mistake(s). Stick to stock tire or slightly narrower ones. Avoid changing the tire profile. Narrower one as in size 205/60/15 (someone mention above), might probably go for this size. Thks. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear February 25, 2012 Share February 25, 2012 Narrower one as in size 205/60/15 (someone mention above), might probably go for this size. Thks. My concern is your safety being compromised by sales-talk at the tyre shop. Link to post Share on other sites More sharing options...
Yuan 6th Gear February 25, 2012 Share February 25, 2012 Narrower one as in size 205/60/15 (someone mention above), might probably go for this size. Thks. If I remember correctly, when I was driving a lancer, I did try on this size and profile. Lasted me quite long but......not as comfortable..... Link to post Share on other sites More sharing options...
Roberttan 5th Gear February 26, 2012 Share February 26, 2012 (edited) If I remember correctly, when I was driving a lancer, I did try on this size and profile. Lasted me quite long but......not as comfortable..... if you are worry and dont trust any shop and why should you listen to people here and if any thing went wrong how? Trust yourself or dont trust any one ? SIMPLE use ONLY stock size (trust your car Maker)\ those sizes quoted or check from website strickly for your general info can.But dont trust them 100% (you dont have to trust me if you want) Edited February 26, 2012 by Roberttan Link to post Share on other sites More sharing options...
Yuan 6th Gear February 26, 2012 Share February 26, 2012 if you are worry and dont trust any shop and why should you listen to people here and if any thing went wrong how? Trust yourself or dont trust any one ? SIMPLE use ONLY stock size (trust your car Maker)\ those sizes quoted or check from website strickly for your general info can.But dont trust them 100% (you dont have to trust me if you want) Eh. not me.....It is TS who is asking...... Link to post Share on other sites More sharing options...
Roberttan 5th Gear February 27, 2012 Share February 27, 2012 (edited) Sorry YUAN , i dont mean you what i am trying to say is IF one does not trust others then just follow your stock SIZE Edited February 27, 2012 by Roberttan Link to post Share on other sites More sharing options...
Btwl Clutched April 1, 2012 Share April 1, 2012 Hi Guys. I would be very grateful if someone can help me with this query. If the rim size is 18" and the original tyre specification is 245/40 R18 but I found the ride a little harsh and noisy, which would be better? (1) change the tyres to 245/45 R18 (2) change the tyres to 235/50 R18? or (3) downsize to 17" and use 235/55 R17 instead? (Assuming using the same tyre brand) Thank you. Link to post Share on other sites More sharing options...
Roberttan 5th Gear April 3, 2012 Share April 3, 2012 Hi Guys. I would be very grateful if someone can help me with this query. If the rim size is 18" and the original tyre specification is 245/40 R18 but I found the ride a little harsh and noisy, which would be better? (1) change the tyres to 245/45 R18 (2) change the tyres to 235/50 R18? or (3) downsize to 17" and use 235/55 R17 instead? (Assuming using the same tyre brand) Thank you. can you give more informations like type /model of car / tyre of tire and rim and pressure you pump? with those infos so we can help you better by changing from 245/40/18 to 245/45/18 not 100% better ride comfort Link to post Share on other sites More sharing options...
Yuan 6th Gear April 3, 2012 Share April 3, 2012 Sorry YUAN , i dont mean you what i am trying to say is IF one does not trust others then just follow your stock SIZE No problem and no worries Robert. It is nice to hear from you again. ↡ Advertisement Link to post Share on other sites More sharing options...
Michelin Primacy 5 Energy
Pirelli P Zero PZ5
Pirelli P Zero PZ5
Petlas Or Giti?
Petlas Or Giti?
