185/65 r15 to195/55 r15
Keen
Can 185/65 r15 tyres change to 195/55r15
I understand most people change from 185/65 to 195/60
Your overall wheel circumference will be much smaller.. not good..
Why no good?
Isnt the same as 215/45/17 to 225/40/17?
Car will be more stable at higher speed and but lower profile means more noisy on the road and more feedback from the roads.....
can change.. but your speedo reading will be off..
one of the many tyre calculator on the web --> Tyre Calculator
Will the reading be way off? DIfference is actually about 4.2%
Edited by Keen
nah usually 2- 5% off only. unless the size you change is very huge in differences.
But u will lose slight comfort as the tyre is thinner. If ur rim is 6.5j, it should be able to take 195 width.
Edited by Bigbadguy
Is 4.2% difference still in the safe range?
If it is in the safe range then I will change it tomorrow.
Worried cos saw some website stating that more then 3% difference will alter the braking system... ABS kick in earlier etc?
Not much of an impact but try to get a profile to as close or accurate as ths speedometer reading.
120.25mm v.s. 107.25mm
Speedometer reading can be off quite a fair bit from actual speed.
Difference try not to be more than 2.5% as recommended by most tyre calculator.
mine came was 195/65/15, i also tot of changing to 195/55/15
but my situation cant so i stay with 65
if u wan comfort, try stay at 65/15
if for cornering, try to change to 55/15, lower profile
but speed reading maybe off 5-10km/hr but its safe
as for my case, i cant go down to 55/15 as my lip with wet kiss with the ground when gng down mscp slope
but hard cornering with 65/15 is scary
hahhhahaahaa
after reading all the + and - points here most will get confused
To me 100% sure improvement stick to your Original size and but the premium quality tyre .
everything comes with the Price.
Speedo meter reading is not very important to me so long you do your reading correction OK
usually, if you are changing your stock wheels for sporty look wheels, most likely, the rim size will up from stock rim & tyre profile height will down from stock tyre.
very simple, measure your stock wheel diameter then look for the biggest allowable rim size + lowest allowable tyre profile height to match closest to your stock wheel diameter.
brother you really go and measure the wheels this way
cos u said reading all the points confusing....so i suggest the fool-proof way lor... :D
Sporty look = more metal, less rubber
Lorry look = more rubber, less metal
overall, you will still need to be as close to the original spec to maintain original car spec performance.
but slightly bigger rim look more fierce lah.... :wub:
Ultimate consideration is safety...go for wider tyre for more contact with the road....175 to 195 for example.
Edited by Cephas
