Discoburg Supersonic June 22, 2012 Share June 22, 2012 Just bought a 2 year old white ride. Removed the emblem and found the dual tone of white. Anyway to polish away the difference? Or any other solution? ↡ Advertisement Link to post Share on other sites More sharing options...
Gee 1st Gear June 22, 2012 Share June 22, 2012 Probably the original paint ba? Polish no use lah. Link to post Share on other sites More sharing options...
Xiaoming99 Neutral Newbie June 22, 2012 Share June 22, 2012 The white under the emblem is the original state of your white, as its protected from the elements by your emblem. The rest of your paint should be slightly more yellowish. So you have to polish your WHOLE car to make the white the same I use Meguairs Ultimate Polish, it works surprisingly well for making white cars white again. Link to post Share on other sites More sharing options...
Nzy Twincharged June 22, 2012 Share June 22, 2012 (edited) Like the others mentioned. That is the original color of your car. If you polish the whole car properly your car should look almost like new and the two tone color will be gone. That is if the color under the emblem is lighter than the color of the other parts of the car. Some cars the emblem doesn't fit properly and water can get under and cause it to be a different color also. Edited June 22, 2012 by Nzy ↡ Advertisement Link to post Share on other sites More sharing options...
COVID-19: Retrenchments
How to remove stubborn stain on windscreen?
Remove Bad Smell In The Car
NUS Grad becomes rubbish collector after retrenchment
My engine after 150,000 kms
Why pple like to change car emblem eg sl350 put sl500
