Newbielee Neutral Newbie November 1, 2012 Share November 1, 2012 Could eye lids just help to minimize the glare coming from aftermarket hid conversion headlamps? By covering a fraction of the top portion of the headlamp, light from hid only shines through the bottom portion of the headlamp casing....hmmmm..what do u think? Peaceful discussion please ↡ Advertisement Link to post Share on other sites More sharing options...
macrosszero Turbocharged November 1, 2012 Share November 1, 2012 No. Link to post Share on other sites More sharing options...
Hamburger Hypersonic November 1, 2012 Share November 1, 2012 Put back the stock light is best Link to post Share on other sites More sharing options...
High_octane 1st Gear November 1, 2012 Share November 1, 2012 I guess it does help if you cover like 1/3 of the headlight... But from LTA site... Tinting or masking of vehicle lamps is not allowed Link to post Share on other sites More sharing options...
Chrispie 5th Gear December 19, 2012 Share December 19, 2012 Could eye lids just help to minimize the glare coming from aftermarket hid conversion headlamps? By covering a fraction of the top portion of the headlamp, light from hid only shines through the bottom portion of the headlamp casing....hmmmm..what do u think? Peaceful discussion please if your headlights are reflector type, please do everyone a favor and remove your hid. It is very glaring to other motorists be it you are oncoming or you are behind. HID should only be used on projector type of headlights. Link to post Share on other sites More sharing options...
Airwaver 4th Gear December 19, 2012 Share December 19, 2012 Why do you want to minimize the glare in the 1st place? So that it doesnt blind the front car? If yes, convert to normal bulbs better. Link to post Share on other sites More sharing options...
Gee 1st Gear December 19, 2012 Share December 19, 2012 You can adjust the angle further down, it may help reduce the glare. Link to post Share on other sites More sharing options...
Sing February 3, 2013 Share February 3, 2013 I think can change light bulb color. The glaring onces are the blue/ white light. If yellow should be ok Link to post Share on other sites More sharing options...
Georgelee Neutral Newbie February 12, 2013 Share February 12, 2013 Why bother? My 2 cents worth ↡ Advertisement Link to post Share on other sites More sharing options...
MOM help FTs look for jobs ?
What could have causes this car to skid so badly?
