Bloggs Neutral Newbie December 6, 2012 Share December 6, 2012 hi to all, as in the topic, any advice on how to get it unstuck and cleaned up? very sticky and very sian. Or any place to recommend that would me remove and clean up? thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Subutai 3rd Gear December 6, 2012 Share December 6, 2012 hi to all, as in the topic, any advice on how to get it unstuck and cleaned up? very sticky and very sian. Or any place to recommend that would me remove and clean up? thanks! DIY with WD40? Link to post Share on other sites More sharing options...
Aurora 1st Gear December 6, 2012 Share December 6, 2012 U can use WD40 or Turpentine to clean it off... Link to post Share on other sites More sharing options...
Picanto 3rd Gear December 6, 2012 Share December 6, 2012 hi to all, as in the topic, any advice on how to get it unstuck and cleaned up? very sticky and very sian. Or any place to recommend that would me remove and clean up? thanks! you should let us know which WS do the SP sheet for you. then we can avoid it Link to post Share on other sites More sharing options...
Edwinatie December 6, 2012 Share December 6, 2012 Looks like they use those cheap material, after some hot sun baking this SP sheet will drop off. Maybe go back to them to remove but its damn a messy and sticky job. Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear December 6, 2012 Share December 6, 2012 Try using lighter fluid... Link to post Share on other sites More sharing options...
Jumpmanz 5th Gear December 7, 2012 Share December 7, 2012 eraser can also do the job but will be taxing. Link to post Share on other sites More sharing options...
Genes 6th Gear December 7, 2012 Share December 7, 2012 Try using lighter fluid... pour le then light it up? Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear December 7, 2012 Share December 7, 2012 pour le then light it up? If you wanna claim insurance...why not.... Lighter fluid will "melt" the adhesive away...so that you can remove it. Another way is to take some rubber adhesive and use it to make a blob...and then use it to dab on the adhesive to "stick" it up from the glass. If using lighter fluid...work on a small area at one time...dun try to remove the whole patch at one go...will make things very messy. Link to post Share on other sites More sharing options...
Koktong2000 Neutral Newbie December 29, 2012 Share December 29, 2012 Can go to Toh guan road east nam Huat audio, they can help u . No point doing yourself Link to post Share on other sites More sharing options...
Kklim Supercharged January 29, 2013 Share January 29, 2013 (edited) Go to Guardian or other pharmacies and ask for IPA (isopropyl alcohol) or denatured alcohol. It helps to soften and dissolve glue, even the strong one on 3M tape. No strong smell. Edited January 29, 2013 by Kklim Link to post Share on other sites More sharing options...
Mcf777 Turbocharged January 29, 2013 Share January 29, 2013 (edited) bro, this is more than 1 month old thread. Anyway, u can use : AXE Brand Oil aka Hong yu (small one cost S$1 to S$2). Perfect oil. Will get the job done swee swee. Edited January 29, 2013 by Mcf777 Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged January 29, 2013 Share January 29, 2013 bro, this is more than 1 month old thread. Anyway, u can use : AXE Brand Oil aka Hong yu (small one cost S$1 to S$2). Perfect oil. Will get the job done swee swee. Somemore can chase Mosquito away in car.. Axe oil contains Eucalyptus essense, natural insect repellent Link to post Share on other sites More sharing options...
Celicar Turbocharged January 29, 2013 Share January 29, 2013 I mountain tortoise, only hear before tinting on window, never heard of soundproofing also on window. Link to post Share on other sites More sharing options...
Xers007 Supercharged January 29, 2013 Share January 29, 2013 I mountain tortoise, only hear before tinting on window, never heard of soundproofing also on window. you not only mountain tortoise but also illiterate... Link to post Share on other sites More sharing options...
Celicar Turbocharged January 29, 2013 Share January 29, 2013 you not only mountain tortoise but also illiterate... How so oh very knowledgeable one? Enlighten me with your wisdom. Link to post Share on other sites More sharing options...
Simplecar 4th Gear February 13, 2013 Share February 13, 2013 the SP added to inside of door melted and the SP piece/s got in contact with the window inside. One way to remove is hair dryer to melt the SP a little while wiping off with newspaper/unwanted pieces of cloth. Using solvent together would be faster. Link to post Share on other sites More sharing options...
Briansoh 1st Gear February 13, 2013 Share February 13, 2013 you not only mountain tortoise but also illiterate... LOL... super funny! Anw TS use the axe oil will be good if you have some readily available. If not some normal cooking oil and the green side of a sponge will do also to help scrub the glass and give it lubricant. ↡ Advertisement Link to post Share on other sites More sharing options...
MOM help FTs look for jobs ?
Citroen C4 1.2 Sensor & Display
