Saabretooth 2nd Gear February 11, 2014 Author Share February 11, 2014 Count, what suspension are you on currently? ↡ Advertisement Link to post Share on other sites More sharing options...
Terry7322 1st Gear February 12, 2014 Share February 12, 2014 u changed a new one? No wonder so expensive. When mine went kapoot, i got it reconned... and so far... works fine. Wallet also happy. but now having some nagging Ss issue.. plus strong smell of petrol. checking on fuel pump already.. Count, Chris How much is the repair for the drive shaft? Mine having same issues with vibrations. My OC blame my driving style. Say tyres falling off already Link to post Share on other sites More sharing options...
Ezfaun 3rd Gear February 12, 2014 Share February 12, 2014 Hello alfa gurus. I'm searching for an alfa after my subaru hunt went kaput. One question, can I put the auto gbox from the alfa 156 3.2 Q4 into the 2.2JTS? I'm guessing no because it's 4wd.. I don't like the selespeed's jerkyness when in auto mode but other than that I like everything else about the 156.. Or maybe the euro diesel version has a conventional gbox.. Link to post Share on other sites More sharing options...
Count_duku 4th Gear February 12, 2014 Share February 12, 2014 (edited) Count, what suspension are you on currently? Eibach pro dampers and springs, lowered about 20mm only - should not be too bad for the CV joint. The flexing of the CV boot could have caused the tear (maybe the damaged shaft bends more than normal), and each time it begins to vibrate/knock I observe a small pin-hole tear by turning the wheel. Hopefully the new drive shaft would solve the problem. Edited February 12, 2014 by Count_duku Link to post Share on other sites More sharing options...
Count_duku 4th Gear February 12, 2014 Share February 12, 2014 (edited) Count, Chris How much is the repair for the drive shaft? Mine having same issues with vibrations. My OC blame my driving style. Say tyres falling off already You can google for Elite Drive Shaft at Sin Ming - they remove the shaft, clean, re-pack the grease with a new boot for $130 (inner and outer boot), about an hours job. Need appointment in advance cos they are usually busy. In my case the repair didn't hold, and the tear appeared again within a few weeks. A new drive shaft is $1500 for 1 side, the drivers side. Given the big different in price it makes sense to go for the recon procedure first. One thing about my drive shaft issue is that the vibration comes only when the accelerator is pressed (torque applied), when I let-go and cruise the car doesn't vibrate. Edited February 12, 2014 by Count_duku Link to post Share on other sites More sharing options...
Saabretooth 2nd Gear February 12, 2014 Author Share February 12, 2014 I see.... my boot tore only when the suspension wore out and started to leak. Only then it tore. You might want to check your height again to see if its too low, or the damping has gone kaput, causing the damping to bottom out. Terry, if you're getting vibrations when driving, it might not be the driveshaft, it could be your wishbones. Like Count said, the driveshafts will make noise only when you acclerate or when you're at full lock and moving off. Link to post Share on other sites More sharing options...
Terry7322 1st Gear February 12, 2014 Share February 12, 2014 (edited) I see.... my boot tore only when the suspension wore out and started to leak. Only then it tore. You might want to check your height again to see if its too low, or the damping has gone kaput, causing the damping to bottom out. Terry, if you're getting vibrations when driving, it might not be the driveshaft, it could be your wishbones. Like Count said, the driveshafts will make noise only when you acclerate or when you're at full lock and moving off. Thanks sabre and count. Yes the issue I have as follows: 1. Vibration during acceleration 2. Increased vibration in proportion with speed and rpm 3. Vibration and knocking sound (like gpmg) stops when I release accelerator pedal. 4. Tires rotated, alignment redone, air pressure checked. Even resorted to changing tyres today cause spotted a crack. Still cannot... Fyi thanks to the red red loud loud 159 owner I got 4 ps3 235/45 for only 230 a piece. Tyres made in France. Edited February 12, 2014 by Terry7322 1 Link to post Share on other sites More sharing options...
Saabretooth 2nd Gear February 12, 2014 Author Share February 12, 2014 99% drive shaft. Link to post Share on other sites More sharing options...
Chrispie 5th Gear February 12, 2014 Share February 12, 2014 i thnk i paid like 700 for recon? Link to post Share on other sites More sharing options...
Saabretooth 2nd Gear February 13, 2014 Author Share February 13, 2014 Took the car for a nice run up the NSH. Driving is really good. :) Link to post Share on other sites More sharing options...
Theoldjaffa Hypersonic February 13, 2014 Share February 13, 2014 u changed a new one? No wonder so expensive. When mine went kapoot, i got it reconned... and so far... works fine. Wallet also happy. but now having some nagging Ss issue.. plus strong smell of petrol. checking on fuel pump already.. check ur fuel cap under the rear seat. mine had a line crack and was leaking.. and petrol fumes in the cabin. 400km and my fuel warning light up liao.. after patching, i can get minimum 480km and that's a 20% improvement.. today it lighted at 520km... so happy. best FC ever in the 3 years 3 months. Link to post Share on other sites More sharing options...
Vhtfhwlego Supercharged February 13, 2014 Share February 13, 2014 Took the car for a nice run up the NSH. Driving is really good. :) took a drive up as well. drive was really really bad. Link to post Share on other sites More sharing options...
Saabretooth 2nd Gear February 13, 2014 Author Share February 13, 2014 took a drive up as well. drive was really really bad. Why so bad? and I am in line for some suspension and wishbone work, and the drive was still good... Link to post Share on other sites More sharing options...
Terry7322 1st Gear February 13, 2014 Share February 13, 2014 Things done over these 3 days. 1. Waited for hours at various workshops for them to diagnose vibrating issues. 2. Changed tyres to PS3 235/45 R17. -> road noise higher than CSC3 3. Reconditioned drive shafts for 9 blues.al issues resolved. CV joint was dry as grease leaked/dripped/poured/evaporated due to tear in rubber boot. 4. Drove home with the biggest smile ever. Just another week in the life of an alfa owner... Link to post Share on other sites More sharing options...
Count_duku 4th Gear February 13, 2014 Share February 13, 2014 bad news - noticed dark green grease seeping out from the clamps of my brand new drive shaft .. sigh, gotta go back again Link to post Share on other sites More sharing options...
Chaona Clutched February 13, 2014 Share February 13, 2014 Thanks sabre and count. Yes the issue I have as follows: 1. Vibration during acceleration 2. Increased vibration in proportion with speed and rpm 3. Vibration and knocking sound (like gpmg) stops when I release accelerator pedal. 4. Tires rotated, alignment redone, air pressure checked. Even resorted to changing tyres today cause spotted a crack. Still cannot... Fyi thanks to the red red loud loud 159 owner I got 4 ps3 235/45 for only 230 a piece. Tyres made in France. Hi bro, could you advise where you got your PS3s from? my tyres are due for a change! Link to post Share on other sites More sharing options...
Toeyritztt 1st Gear February 13, 2014 Share February 13, 2014 Changed my radiator hoses complete..upper n lower. Thermal wrapped the plastic-hoses for ....dunno y! haha... flushed in new coolant, serviced with Syntium 3000AV, changed both rear engine stabilizers... ended it al with a good engine wash! oh!gosh! she feels well & vibrant now, somewhat... hehehe... Link to post Share on other sites More sharing options...
Terry7322 1st Gear February 13, 2014 Share February 13, 2014 Hi bro, could you advise where you got your PS3s from? my tyres are due for a change! Chaona I got the tyres from kah tyres at lavender. It's a few shops down from city tyres in the direction towards balestier road. However, those 4 were the last set. Sorry. They do carry the new falken 453 though. Maybe you can go down to take a look. ↡ Advertisement Link to post Share on other sites More sharing options...
2022 Alfa Romeo Tonale (965)
The 2017 Alfa Romeo Giulia
NDR 2024: What you need to know of key topics in PM Wong's speeches
