Naughty9795 2nd Gear August 31, 2013 Share August 31, 2013 Hi, has anyone try the Red Angel stop leak for aircon? It also comes with One Shot which is easy to use. I wanted to try it but the shipping is expensive. http://www.gobluedevil.com/oneshotr134astopleak.html ↡ Advertisement Link to post Share on other sites More sharing options...
Rustyz 5th Gear August 31, 2013 Share August 31, 2013 Hi, has anyone try the Red Angel stop leak for aircon? It also comes with One Shot which is easy to use. I wanted to try it but the shipping is expensive. http://www.gobluedevil.com/oneshotr134astopleak.html Have u located and know how bad is the leaking? I would do that before buying and keep in mind U will still need top of the refrigerant and maybe aircon shop can do it cheaper for u. My 2 cents of thought Link to post Share on other sites More sharing options...
Naughty9795 2nd Gear August 31, 2013 Author Share August 31, 2013 The air con guy suspect the evaporator is leaking, nothing is firm unit the remove the dashboard which is labour intensive. Gas only last for a month. Link to post Share on other sites More sharing options...
Rustyz 5th Gear September 1, 2013 Share September 1, 2013 The air con guy suspect the evaporator is leaking, nothing is firm unit the remove the dashboard which is labour intensive. Gas only last for a month. Like that is worth trying. Try find another car air con specialist to check Link to post Share on other sites More sharing options...
Pisces69 6th Gear September 1, 2013 Share September 1, 2013 Hi, has anyone try the Red Angel stop leak for aircon? It also comes with One Shot which is easy to use. I wanted to try it but the shipping is expensive. http://www.gobluedevil.com/oneshotr134astopleak.html Most of those "stop leak" products dun really work or might just b a temporary measure n then it wil leak again. Many even clog up the whole system n u might need to spend much more later to change many parts that were clogged up by it. U can try n post the results here for us to see. Link to post Share on other sites More sharing options...
Naughty9795 2nd Gear September 4, 2013 Author Share September 4, 2013 I went to markcool, they said condenser leak. Then I went to motoraire , the inject tracing dye and gas. My aircon because not cool again after a month. I went back to motoraire and the can't find the leakage, that why they suspect the evaporator which is hidden under the dashboard. I had bought from ebay and waiting for the arrival. Will update you guy. Thanks Link to post Share on other sites More sharing options...
Pisces69 6th Gear September 4, 2013 Share September 4, 2013 I went to markcool, they said condenser leak. Then I went to motoraire , the inject tracing dye and gas. My aircon because not cool again after a month. I went back to motoraire and the can't find the leakage, that why they suspect the evaporator which is hidden under the dashboard. I had bought from ebay and waiting for the arrival. Will update you guy. Thanks OK let us know how good but these things maybe wil only spoil the system after some time. ↡ Advertisement Link to post Share on other sites More sharing options...
Rich people's lifestyles
Discriminatory practices towards the aged
Coolant level going down
Man who removed bus stop bench to check its dimensions for f
Stop False Accusation
Hackers leak 190GB of data allegedly from Samsung, includes source code and biometric unlocking algorithms
