Jameschia26 1st Gear June 30, 2014 Share June 30, 2014 Went to Autobacs to do a tyre rotation & balancing. The mechanic told me that there is a crack at my front control arms and suggest I change both to an OEM one for $600 incl labour. Though I can't really tell if its cracked or not, can I check if this is a critical component to be changed? I'm driving FD1 (now about 6 yrs old). Wondering if I can use it till COE expire.. ↡ Advertisement Link to post Share on other sites More sharing options...
Trafficwatch Clutched June 30, 2014 Share June 30, 2014 Went to Autobacs to do a tyre rotation & balancing. The mechanic told me that there is a crack at my front control arms and suggest I change both to an OEM one for $600 incl labour. Though I can't really tell if its cracked or not, can I check if this is a critical component to be changed? I'm driving FD1 (now about 6 yrs old). Wondering if I can use it till COE expire.. Should be front lower arm (Located at front left and right wheel discs). U can got to Fong Tat Motor (junction of Serangoon Rd / Kitchener Rd) and buy your own parts (Approx S$ 150 per pc x 2 pcs = S$ 300/-) and get your usual WS to replace it (Labor should be around S$ 50 to S$ 60/-). Head Office (Operations & Sales)Fong Tat Building, No. 3 Kallang Way 2A, Singapore 347493 T:(65) 6742 6889 For General Enquires: E:[email protected] Sales Outlets (Singapore)355-357, Serangoon Road, Singapore 218115 T:(65) 6298 5333 Blk 685, #01-324 Race Course Road, S'pore 210685 T:(65) 6293 5722 Link to post Share on other sites More sharing options...
Hussaini20 3rd Gear June 30, 2014 Share June 30, 2014 Went to Autobacs to do a tyre rotation & balancing. The mechanic told me that there is a crack at my front control arms and suggest I change both to an OEM one for $600 incl labour. Though I can't really tell if its cracked or not, can I check if this is a critical component to be changed? I'm driving FD1 (now about 6 yrs old). Wondering if I can use it till COE expire.. Unless you wanna drive on 3 wheels, I suggest go and change.. 600 for both oem seems ok.. Can get cheaper from other plcs though.. Try ask stockists for a pair and get a workshop to fix it.. Should be at least cheaper.. Used to have this prob on my old lancer. Got both change @ 450 labour inclusive. Link to post Share on other sites More sharing options...
TVT Supercharged June 30, 2014 Share June 30, 2014 How did such a crack come about? Did you drove over a edge and drop down n hit it ? Link to post Share on other sites More sharing options...
Trafficwatch Clutched June 30, 2014 Share June 30, 2014 How did such a crack come about? Did you drove over a edge and drop down n hit it ? It's under wear & tear. Link to post Share on other sites More sharing options...
Jameschia26 1st Gear June 30, 2014 Author Share June 30, 2014 How did such a crack come about? Did you drove over a edge and drop down n hit it ? Eh, think its just wear and tear as I don't really drive very hard. In fact its both the front arms the mechanic claim had cracks. So need to change both. Should be front lower arm (Located at front left and right wheel discs). U can got to Fong Tat Motor (junction of Serangoon Rd / Kitchener Rd) and buy your own parts (Approx S$ 150 per pc x 2 pcs = S$ 300/-) and get your usual WS to replace it (Labor should be around S$ 50 to S$ 60/-). Head Office (Operations & Sales)Fong Tat Building, No. 3 Kallang Way 2A, Singapore 347493 T:(65) 6742 6889 For General Enquires: E:[email protected] Sales Outlets (Singapore)355-357, Serangoon Road, Singapore 218115 T:(65) 6298 5333 Blk 685, #01-324 Race Course Road, S'pore 210685 T:(65) 6293 5722 Thanks! Will check them out Link to post Share on other sites More sharing options...
Lattesurf Neutral Newbie June 30, 2014 Share June 30, 2014 Prolong driving with worn/damaged control arms will result in knocking sounds when driving slow over humps or turns. Wobbly steering and premature wear of front tyres. Won't have life threatening consequences. Actually it's the rubber bushings that are torn/crack and causing all the sounds. But SG don't really have workshops that replace the bushings. So most will tell you just replace the whole left/right arms. As others mentioned, try buying the parts from stockists and go to outside workshops to replace, will be cheaper. When I last changed my lower control arms, droplinks and steering tie rods, after 6 years, my car steering suddenly felt nice and firm and no more knocking sounds. ↡ Advertisement Link to post Share on other sites More sharing options...
[Concept] Honda 0 Series EVs
2022 Toyota GR Corolla
Battery for Honda Vezel
