Souma Clutched October 21, 2014 Share October 21, 2014 (edited) Hope fellow bros and sisters can advise... pardon me if the explanation is not clearTo switch on a car headlights, just turn the signal knob right? Turn once, for small lights plus fog lamp (if toggled on) and turn fully for big lights plus fog lamp (if toggled on).Now the current issue...Fog lamp is toggled on. Turn knob once but no lights from headlights nor fog lamp, not even rear lights! But when brakes are depressed, rear lights and brake light activated. HUD headlights icon not shown.Fog lamp still toggled on. Fully turned the knob, this time big headlights activated however it is not the case for fog lamp and rear lights. HUD headlights icon still not shown.I've changed a new battery but problem still persist.So what's the problem here? Which component is spoilt or faulty? Edited October 23, 2014 by BabyBlade ↡ Advertisement Link to post Share on other sites More sharing options...
QQDreamer 4th Gear October 21, 2014 Share October 21, 2014 (edited) your headlamp switch is faulty already. or could be headlamp relay problem. Edited October 21, 2014 by MkMan Link to post Share on other sites More sharing options...
Souma Clutched October 21, 2014 Author Share October 21, 2014 your headlamp switch is faulty already. or could be headlamp relay problem. Wah then if buy from stockist will it be expensive? What is the actual name used for this part? Link to post Share on other sites More sharing options...
QQDreamer 4th Gear October 21, 2014 Share October 21, 2014 Wah then if buy from stockist will it be expensive? What is the actual name used for this part? shouldnt be too ex i guess. but why not sent it for a check first? Link to post Share on other sites More sharing options...
Chowyunfatt Turbocharged October 21, 2014 Share October 21, 2014 Hope fellow bros and sisters can advise... pardon me if the explanation is not clear To switch on a car headlights, just turn the signal knob right? Turn once, for small lights plus fog lamp (if toggled on) and turn fully for big lights plus fog lamp (if toggled on). Now the current issue... Fog lamp is toggled on. Turn knob once but no lights from headlights nor fog lamp, not even rear lights! But when brakes are depressed, rear lights and brake light activated. HUD headlights icon not shown. Fog lamp still toggled on. Fully turned the knob, this time big headlights activated however it is not the case for fog lamp and rear lights. HUD headlights icon still not shown. I've changed a new battery but problem still persist. So what's the problem here? Which component is spoilt or faulty? May I ask ... What Car? ... Just curious .... Link to post Share on other sites More sharing options...
Watwheels Supersonic October 21, 2014 Share October 21, 2014 There's a module or ecu to control your signal, lights and wipers. If you haven't done anything to the circuit it is likely the module is faulty. Did you install anything electrical of late?...W/o disconnecting the negative side of the battery terminal? ↡ Advertisement Link to post Share on other sites More sharing options...
Is it possible to keep deregistered cars?
Toyota Corolla Cross
Toyota Land Cruiser Mini
Toyota bZ4X (2026) Part 2
Sunway Circuit Iskandar Puteri
2022 Toyota bZ4X
2022 Toyota bZ4X
