carloverguy2017 5th Gear May 19, 2017 Share May 19, 2017 Installed a full set of lowering springs from Storm. Progressive springs, red and made in Korea specifically matched to your Hyundai / Kia models My first day of field report for the Storm Progressive Lowering Spring , here goes. Compared to coil overs, these are not adjustable for dampening nor height. Installation is a breeze as it only requires removal of stock shocks/ spring and replacing the stock springs with the Storm. Practically no alignment is necessary since your camber ( for most passenger cars ) are no adjustable. Castor for almost all car models are also fixed, so no alignment is possible. Toe in shouldn't be affected since toe tie rods will not be loosen or touched during installation. On the road, the ride is surprisingly soft. Compared to coilovers, these progressives have a almost close to stock first few CM of compression which soaks up the roughness of the road. However during cornering, the progressives nature would feel harder and harder as your corner hits more corner speed. Hence it doesn't feel like you are going to roll over feeling like in a stock. The lowered look, which has always been my cup of tea for almost all my cars except one, gives a farily equal gap all around the tyres and fenders. Over humps, no issue since it only lowers 3.5 cm front and 3 cm rear. Compared to my coilovers which was lowered to the max, didn't had problem going over humps either. So verdict.. if you are looking at lowering, progressive is way to go. Linear springs are just too harsh, base on my experience. ↡ Advertisement Link to post Share on other sites More sharing options...
flashbang Turbocharged May 20, 2017 Share May 20, 2017 Installed a full set of lowering springs from Storm. Progressive springs, red and made in Korea specifically matched to your Hyundai / Kia models My first day of field report for the Storm Progressive Lowering Spring , here goes. Compared to coil overs, these are not adjustable for dampening nor height. Installation is a breeze as it only requires removal of stock shocks/ spring and replacing the stock springs with the Storm. Practically no alignment is necessary since your camber ( for most passenger cars ) are no adjustable. Castor for almost all car models are also fixed, so no alignment is possible. Toe in shouldn't be affected since toe tie rods will not be loosen or touched during installation. On the road, the ride is surprisingly soft. Compared to coilovers, these progressives have a almost close to stock first few CM of compression which soaks up the roughness of the road. However during cornering, the progressives nature would feel harder and harder as your corner hits more corner speed. Hence it doesn't feel like you are going to roll over feeling like in a stock. The lowered look, which has always been my cup of tea for almost all my cars except one, gives a farily equal gap all around the tyres and fenders. Over humps, no issue since it only lowers 3.5 cm front and 3 cm rear. Compared to my coilovers which was lowered to the max, didn't had problem going over humps either. So verdict.. if you are looking at lowering, progressive is way to go. Linear springs are just too harsh, base on my experience. Whats the damage and where you got it fixed? Link to post Share on other sites More sharing options...
carloverguy2017 5th Gear May 21, 2017 Author Share May 21, 2017 Whats the damage and where you got it fixed? What car are you driving ? The brand of progressive lowering springs are specifically catered for the Korean market makes only - Hyundai & Kia. Do a search for Storm brand lowering springs. Ebay. Some sellers have free shipping. I got mine just under USD300 free shipping. Install can be done at any workshop because it is a simple job. Link to post Share on other sites More sharing options...
bttoh 1st Gear May 21, 2017 Share May 21, 2017 thanks for your advice Link to post Share on other sites More sharing options...
Sdf4786k Twincharged May 21, 2017 Share May 21, 2017 just be careful and monitor after install. the split where the two different set of sprint meets can "run" out of alignment and that's where u get funky steering and ride jiggers Link to post Share on other sites More sharing options...
carloverguy2017 5th Gear May 21, 2017 Author Share May 21, 2017 (edited) https://www.youtube.com/watch?v=ht2Fl6oPZug Used my mobile phone to film some bits of the car today after a good car wash. Mobile phones can do good sh*t seriously ! However there are technical problem with such cheap mobile phone filming is that the focusing is always constantly changing and you cannot keep the subject in perfect focus as you move around due to reflection and light changes ( shadow ). Also with light weight mobile phones, video tends to be very shaky and jerky as you pan. I would usually use my Digital DSLR for more serious projects as it produce true 4K format. just be careful and monitor after install. the split where the two different set of sprint meets can "run" out of alignment and that's where u get funky steering and ride jiggers May I understand what you meant by the "sprint meets" ? Edited May 21, 2017 by carloverguy2017 ↡ Advertisement Link to post Share on other sites More sharing options...
2026 Hyundai Palisade: This Is It
2022 Toyota GR Corolla
Coolant level going down
