Maomao82 2nd Gear March 30, 2019 Share March 30, 2019 Bro as i understand, you cannot share the battery between green and yellow models. Personally I would prefer the green one as the battery is stronger and last longer. I also heard cannot.. but my friend got from a carousell hydrojet dealer 5.0aH green batt used on his orange Hydroshot.. 1year plus no issue.. Worx wu230. https://m.facebook.com/1912010095747975/videos/464459120732682/&ved=0ahUKEwj35-CLiafhAhVIuI8KHYLvBaAQo7QBCDcwCQ&usg=AOvVaw0CfESVay2A7hNb5Jj50xa9 How would u rate this model for yr requirement? partially met? Met, Exceeded? ↡ Advertisement Link to post Share on other sites More sharing options...
ksmx Neutral Newbie April 4, 2019 Share April 4, 2019 Don't say bojio - flash deal on Shopee. 2 more hours! https://shopee.sg/hydrojet/1873712309?smtt=0.0.9 Link to post Share on other sites More sharing options...
Maomao82 2nd Gear April 4, 2019 Share April 4, 2019 Don't say bojio - flash deal on Shopee. 2 more hours! https://shopee.sg/hydrojet/1873712309?smtt=0.0.9 What was the promo? only manage to see this now.... Link to post Share on other sites More sharing options...
Count-Bracula Twincharged April 28, 2019 Share April 28, 2019 Use my Worx Hydroshot first time today. This is my last time washing my Nissan Sunny. It only took one big pail of water to rinse and wash car. One quarter pail to rinse. Spray foam as in snow wash not with Worx foam attachment but pressurized foam spray. Covered whole car with foam. Waited 5 mins then rinse completely with the remaining 3 quarter pail of water. Wipe dry with micro fibre cloth. Very efficient, time and water saving compared to washing car previously. No more car wash at petrol kiosk from now on. 3 Link to post Share on other sites More sharing options...
Benchong05 3rd Gear April 29, 2019 Share April 29, 2019 Happen to see another Worx lookalike in Qoo10 and the price is cheaper as well, the logo also looks similar to Worx : https://www.qoo10.sg/item/PORTABLE-POWER-CLEANER-LI-ION-PRESSURE-WASHER-CLEANER-GUN-CAR/652481658 Link to post Share on other sites More sharing options...
HaimVais Clutched April 29, 2019 Share April 29, 2019 Hello, There is a new pressure washer cordless- K2 Follow Me 60BAR by KARCHER: https://www.kaercher.com/sg/home-garden/pressure-washers/k2-follow-me-cordless-kap-11171060.html unfortunately there is no review\ video about this tool. Someone tried this pressure washer? Thanks Link to post Share on other sites More sharing options...
5kylark April 30, 2019 Share April 30, 2019 Happen to see another Worx lookalike in Qoo10 and the price is cheaper as well, the logo also looks similar to Worx : https://www.qoo10.sg/item/PORTABLE-POWER-CLEANER-LI-ION-PRESSURE-WASHER-CLEANER-GUN-CAR/652481658 China very quick to COPY ideas... at this price, the pressure does not seem as high as WORX. Link to post Share on other sites More sharing options...
5kylark April 30, 2019 Share April 30, 2019 Happen to see another Worx lookalike in Qoo10 and the price is cheaper as well, the logo also looks similar to Worx : https://www.qoo10.sg/item/PORTABLE-POWER-CLEANER-LI-ION-PRESSURE-WASHER-CLEANER-GUN-CAR/652481658 China very quick to COPY ideas... at this price, sure attract some buyers. Max is 0.9 MPA only. Link to post Share on other sites More sharing options...
kopfan 3rd Gear May 1, 2019 Share May 1, 2019 Hello, There is a new pressure washer cordless- K2 Follow Me 60BAR by KARCHER: https://www.kaercher.com/sg/home-garden/pressure-washers/k2-follow-me-cordless-kap-11171060.html unfortunately there is no review\ video about this tool. Someone tried this pressure washer? Thanks My friend using it and it is good. More powerful pressure than worx but not as portable. If you need more power, go for karcher. Worx give you the portability and easy storage. Both having their pro and cons. Link to post Share on other sites More sharing options...
HaimVais Clutched May 1, 2019 Share May 1, 2019 My friend using it and it is good. More powerful pressure than worx but not as portable. If you need more power, go for karcher. Worx give you the portability and easy storage. Both having their pro and cons. Thanks. karcher says that it 60BAR pressure washer. Its is true that it can perform 60BAR from his bucket? You checked? Link to post Share on other sites More sharing options...
Mockngbrd Supersonic May 2, 2019 Share May 2, 2019 Even those high pressure high output foam cannon that people use they also mix their car shampoo with water.. try dilute your car shampoo and give it a try.. you may be surprised that you don't need the full concentrated volume. for a weekend carwash guy, your effort also not simple! Yup. Am using a foam gun. I dilute with water and the gun and a just mixing ratio also. else super waste the soap. Link to post Share on other sites More sharing options...
Knoobie Supercharged May 2, 2019 Share May 2, 2019 (edited) My friend using it and it is good. More powerful pressure than worx but not as portable. If you need more power, go for karcher. Worx give you the portability and easy storage. Both having their pro and cons. according to specs, the pressure appears to be twice the 40v hydroshot. but the flow rate seems to be the same at approx 1gpm.. I wonder if the lance is standard quick connect so can buy third party foam cannon to use.. if it is, maybe considering it to replace my xiaomi jimmy go dead. Edited May 2, 2019 by Knoobie Link to post Share on other sites More sharing options...
Fsrkia Neutral Newbie May 2, 2019 Share May 2, 2019 Yup. Am using a foam gun. I dilute with water and the gun and a just mixing ratio also. else super waste the soap. May I know where u purchase your foam gun? Do you have a picture of it? Does it require any hose connection? Link to post Share on other sites More sharing options...
Mockngbrd Supersonic May 2, 2019 Share May 2, 2019 May I know where u purchase your foam gun? Do you have a picture of it? Does it require any hose connection? Ebay (like 7-8 years ago) Yes. Normal hose with quick lock connectors. Link to post Share on other sites More sharing options...
Knoobie Supercharged May 6, 2019 Share May 6, 2019 Ebay (like 7-8 years ago) Yes. Normal hose with quick lock connectors. I instead settled for a foam sprayer as I find foam gun in MCSP a bit waste on the 20cts and water.. Link to post Share on other sites More sharing options...
Fsrkia Neutral Newbie May 6, 2019 Share May 6, 2019 I instead settled for a foam sprayer as I find foam gun in MCSP a bit waste on the 20cts and water..Where to get a foam sprayer?? Any recommended ones? Link to post Share on other sites More sharing options...
Knoobie Supercharged May 7, 2019 Share May 7, 2019 Where to get a foam sprayer?? Any recommended ones? I got my IK Foam Sprayer from Lazada after watching how it works on Youtube. There are 3 different tips provided for dry, standard or wet foam. One full bottle should be sufficient enough for a whole car. Only drawback is you have to keep pumping the bottle... Unless you get the bigger one which is IK 9. Link to post Share on other sites More sharing options...
SkimMilk 3rd Gear May 9, 2019 Share May 9, 2019 Hi all, for those interested, Tmall international is having a sale on the WG629.E4 model (2.5Ah battery) with free sea shipping. If you have coupons, can reduce the price to lower than SGD$120. Here's the link ↡ Advertisement Link to post Share on other sites More sharing options...
2025 BMW X3 G45
2025 BMW X3 G45
All BMW owner thread
Online purchase for car parts
i Wake Up Naked Today Morning
