AXO_vampire Neutral Newbie May 26, 2019 Share May 26, 2019 Different and cannot use.Noted, thank you for the advise ↡ Advertisement Link to post Share on other sites More sharing options...
Ct3833 Supersonic June 10, 2019 Share June 10, 2019 @RadX I only have budget for throttle controller or RS chip. Which one would you recommend? In btw heard stories of how RS chip might damage ur car... dont know real or not...RS give you better power, throttle controller gives you quicker throttle response.So with only a RS chip, you would still feel the accelerator lag but once overcome , the additional power will come in. With only the throttle controller, you get better accelerator response but no change in power. Link to post Share on other sites More sharing options...
Wolverine23 1st Gear July 26, 2019 Share July 26, 2019 @RadX RS give you better power, throttle controller gives you quicker throttle response. So with only a RS chip, you would still feel the accelerator lag but once overcome , the additional power will come in. With only the throttle controller, you get better accelerator response but no change in power. Is Pivot 3-Drive good? Or anything else to recommend? 1 Link to post Share on other sites More sharing options...
Discoburg Supersonic July 26, 2019 Share July 26, 2019 Tried before. Like what the others say. You will get the feeling of faster respond. Is Pivot 3-Drive good? Or anything else to recommend? Link to post Share on other sites More sharing options...
Wolverine23 1st Gear July 28, 2019 Share July 28, 2019 Tried before. Like what the others say. You will get the feeling of faster respond. ok, I am trying to get one. Which are the brands/ models to consider? 1 Link to post Share on other sites More sharing options...
Discoburg Supersonic July 28, 2019 Share July 28, 2019 Pivot 3 drive was like ten years back. Not sure whether is McWell still around or are they still selling it. I am not into these stuffs so I can't recommend. By the way have you looked at sprint booster? ok, I am trying to get one. Which are the brands/ models to consider? Link to post Share on other sites More sharing options...
Wolverine23 1st Gear July 28, 2019 Share July 28, 2019 Pivot 3 drive was like ten years back. Not sure whether is McWell still around or are they still selling it. I am not into these stuffs so I can't recommend. By the way have you looked at sprint booster? no, not. Will check out sprint booster ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota bZ4X (2026) Part 2
Next Generation Toyota Crown
Toyota Corolla Cross
Toyota Land Cruiser Mini
2022 Toyota bZ4X
2022 Toyota bZ4X
