detached2007 Neutral Newbie January 13, 2023 Share January 13, 2023 Hi bros, Bought a 2nd hand car with a preinstalled Vess Head Unit. There's a connector which I supposed to put in a SIM card, I tried but it doesn't detect the SIM card. Where can I go to rectify the issue? ↡ Advertisement Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear January 14, 2023 Share January 14, 2023 Hi Try to reset the system. 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator January 16, 2023 Share January 16, 2023 On 1/14/2023 at 8:48 PM, Gadgeter said: Hi Try to reset the system. Happy new year boss! Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear February 3, 2023 Share February 3, 2023 On 1/16/2023 at 9:14 AM, kobayashiGT said: Happy new year boss! Happy New Year! Link to post Share on other sites More sharing options...
Mancypher 3rd Gear February 9, 2023 Share February 9, 2023 On 1/13/2023 at 11:26 PM, detached2007 said: Hi bros, Bought a 2nd hand car with a preinstalled Vess Head Unit. There's a connector which I supposed to put in a SIM card, I tried but it doesn't detect the SIM card. Where can I go to rectify the issue? Vess is Android Player i assume. Firstly, locate your 4G antenna connected to your player. Should be at dashboard or somewhere high up. This one dont have, you put 10 diff SIM also no use. Then do the following below: 1. Reset the head unit. 2. Put SIM card. Reboot the head unit. 3. If reboot successful, you should see the SIM signal bar. Check APN in setting. You may need to manually enter APN. 4. If reboot and still same, you may need to check the wiring. [improper soldering, soldered wire came off, etc] For point 4, if you know how to rectify, can DIY. Else, go shop do. ↡ Advertisement Link to post Share on other sites More sharing options...
Ice Skating
Ice Skating
Woman cashes in from selling her urine with buyers making ice cream from it
VW Will Spend Billions of Its EV Development Budget on Gas Engines
Car Show 2024
Car Show 2024
The Doctor , Freelance ICE Tuner
