Pauly75ts Neutral Newbie August 12, 2003 Share August 12, 2003 "the beauty of MCF, help me know more about car " Hi! there, Sapporo, The members here are a helpful bunch, I too, have learnt alot in here. Rgds Paul Yong ↡ Advertisement Link to post Share on other sites More sharing options...
Assassin Clutched August 12, 2003 Share August 12, 2003 Thks for your info bro Btw, what is the different between brembomax and the 'Real' Brembos? Tot the should be the same, a bit From http://hp.brembo.com/brandlist.asp There are 2 types....Brembo Sport... and the high end Brembo Gran Turismo. Link to post Share on other sites More sharing options...
Sapporo Neutral Newbie August 16, 2003 Author Share August 16, 2003 Hi YTTRIUM, After I've changed the mintex pad for three days, done the pad bedding recom by mintex. Currently, everytime when braking there is this 'squeal' sound. It is normal? Since you've driven ES8 with mintex, can you advise me what might happened Thks Link to post Share on other sites More sharing options...
Yttrium Neutral Newbie August 16, 2003 Share August 16, 2003 Doesn't sound normal for new pads.. sorry if I gave you the wrong impression.. The ES8 that I drove was my friend's so I did not have any personal experience installing it. Did you install the pads with any shims? Link to post Share on other sites More sharing options...
Sapporo Neutral Newbie August 16, 2003 Author Share August 16, 2003 Shims? You means the shims behind the pad? There is a pcs of thin metal behind the pad, is that the shim? Link to post Share on other sites More sharing options...
Yttrium Neutral Newbie August 16, 2003 Share August 16, 2003 Yup, that's the shim. You might also want to refer to this previous thread on brake squeal http://www.mycarforum.com/forum/gforum.cgi...0squeal;#108728 Link to post Share on other sites More sharing options...
Sapporo Neutral Newbie August 17, 2003 Author Share August 17, 2003 Thks bro. Link to post Share on other sites More sharing options...
Yttrium Neutral Newbie August 18, 2003 Share August 18, 2003 You're welcome ↡ Advertisement Link to post Share on other sites More sharing options...
Upgrading stock horn
Brake Pads
Brake Pads
Brake squeak every morning
Upgrading - Home Improvement Program HIP
