Hitman Neutral Newbie August 11, 2003 Share August 11, 2003 There has been a couple of discussions on this topic but I am rather lost in finding it. I know some of you has stated that Japanese cars run a richer mixture. My question is :- 1) What would be the causes for the mixture to be tuned to a lean mixture ? 2) Besides the Greddy E-Manage that allows you to tune this mixture, what would the agents do if it is discovered the fuel mixture is too lean. Reset ECU ?? 3) What would be the distinct signs of a too lean or too rich fuel mixture. What would the drivers have to look out for as symptoms ? 4) If a CAI have been newly installed, would you need to re-tune your mixture ? Thank you for all the help. ↡ Advertisement Link to post Share on other sites More sharing options...
Cool Neutral Newbie August 11, 2003 Share August 11, 2003 (edited) call me to view my car lar, then you will know. picture paints a thousand words... Edited August 11, 2003 by Cool Link to post Share on other sites More sharing options...
Hitman Neutral Newbie August 11, 2003 Author Share August 11, 2003 "Piggy backs actually re-maps the Fuel Mapping bypassing the stock ECU." Are piggy backs a complicated procedure or is it better to use .... Would you need a laptop for it. I am not technically inclined with graphs and maps so how user-frinedly is the software ?? Link to post Share on other sites More sharing options...
Cool Neutral Newbie August 11, 2003 Share August 11, 2003 Lets take it off line cos I don't want to be mistaken for teaching anyone how to reset their own Mazda ecu and get warranty void.. Link to post Share on other sites More sharing options...
Hitman Neutral Newbie August 11, 2003 Author Share August 11, 2003 Ok Link to post Share on other sites More sharing options...
Hitman Neutral Newbie August 11, 2003 Author Share August 11, 2003 Ok lar ..... but u stay belly belly far from me lah ... next meetup can ? When u going to Japan ?? Link to post Share on other sites More sharing options...
Cool Neutral Newbie August 11, 2003 Share August 11, 2003 I work in Town, can meet up at Kallang Macs, you buy me a vanilla coke lar.. Next week.. won't be going MCF meetup often due to work commitments. Link to post Share on other sites More sharing options...
Silver_z 1st Gear August 11, 2003 Share August 11, 2003 1) What would be the causes for the mixture to be tuned to a lean mixture ? E Manage, SAFC, ECU chips, Programmeable ECU, Excessive mod for air intake(ie, turbo, supercharger) without compensation for fuel(fuel regulator or bigger injectors) 2) Besides the Greddy E-Manage that allows you to tune this mixture, what would the agents do if it is discovered the fuel mixture is too lean. Reset ECU ?? They will say your fuel pump, fuel regulator, injectors or fuel rail spoil, then charge you a bomb for replacing perfectly alright parts. 3) What would be the distinct signs of a too lean or too rich fuel mixture. What would the drivers have to look out for as symptoms ? Too lean can hear engine knock. Too rich, your car will be jerky and sluggish. 4) If a CAI have been newly installed, would you need to re-tune your mixture ? Yes. Cause if you previously use a SRI, the air intake is much higher than a CAI, due to the less restrictions of a SRI setup. So a CAI will give you less intake, hence creating a richer mixture. If you are talking about modding a stock intake with open pod setup, then we have more air entering thus resulting in a leaner environment, and the tuning must be made to compensate the fuel entering. Link to post Share on other sites More sharing options...
Flaser Neutral Newbie August 11, 2003 Share August 11, 2003 Lets take it off line cos I don't want to be mistaken for teaching anyone how to reset their own Mazda ecu and get warranty void.. Hi Hitman and Cool, can count me in too? Keen to learn more about my own car too. I work in town too, I can also meet at Kallang. Link to post Share on other sites More sharing options...
Cool Neutral Newbie August 11, 2003 Share August 11, 2003 1. Too much air will make the combustion leaner 2. E-Manage has a subset component for Fuel like SAFC (Super Air Flow COnverter). What it does is that it sense a signal back to the ECU and allow a specific amount of fuel to combust with the air. SAFC is an Apexi product. Reset ECU won't help as the fuel MAP on your stock ECU is fixed. Piggy backs actually re-maps the Fuel Mapping bypassing the stock ECU. 3. Too Lean - WHite Smoke Too Rich - Carbon Deposit at the tail pipe. You need to clean off your tail pipe and observe over period of time. Blue smoke, is to the extreme. Engine Knocking if you can hear, too late already.. to hear ping, you need a special device. 4. Tough answer - You need a Air Fuel Ratio meter to determine at Full Throttle and at Idle. Normally, if it is too lean, at idle, it will sufer vibration. Too Rich, car accelaration very sluggish. my 2 cents worth... Link to post Share on other sites More sharing options...
French_porn Neutral Newbie August 17, 2003 Share August 17, 2003 hi cool. just to check with u. between e-manage and safc,if i buy the 2nd hand one,which is a better catch? no money to buy 1st hand one or save the money to buy the 1st hand one? Link to post Share on other sites More sharing options...
Zrun Neutral Newbie September 2, 2003 Share September 2, 2003 Besides the Greddy E-Manage that allows you to tune this mixture, what would the agents do if it is discovered the fuel mixture is too lean. Reset ECU ?? You mean "the agent"? They will morph into 10 different agents and charge you 10 times the price... :) Usually too lean/too rich is not indication of bad tuning in ECU, as it is already fixed... It is usually caused by bad O2 sensors, bad crank angle sensor timing.. Link to post Share on other sites More sharing options...
Zrun Neutral Newbie September 2, 2003 Share September 2, 2003 you mean it is different than just diconnecting the ECU fuse for 10 mins? Link to post Share on other sites More sharing options...
Cool Neutral Newbie September 2, 2003 Share September 2, 2003 some cars needs to jump the switch to sent a signal to the ecu to "reset" Link to post Share on other sites More sharing options...
Zrun Neutral Newbie September 2, 2003 Share September 2, 2003 What's the difference in features and cost of Greddy EManage package vs Apexi S-AFC? Link to post Share on other sites More sharing options...
Phochem Neutral Newbie September 2, 2003 Share September 2, 2003 ... ... 3) What would be the distinct signs of a too lean or too rich fuel mixture. What would the drivers have to look out for as symptoms ? ... ... check your sparkplugs.... the best answer http://www.densoiridium.com/howtoreadusedplugs.php Link to post Share on other sites More sharing options...
Cool Neutral Newbie September 3, 2003 Share September 3, 2003 Firstly, there is a vast difference between Emanage and SAFC. EMange: 1. Controls Iginition Timing 2. Controls Knocking (which is better left untouch) 3. Controls Air-Fuel Ratio 4. COntrols Boost for Turbo 5. Add additional injectors 6. Not visible unless you hook on to a E-Profec or laptop (additional purchase neede) Price S$(750) SAFC. 1. Has display 2. Controls Air-fuel Ratio ONLY (no ignition timing or boost) Price: S$630 You need an ITC which cost S$500 to add on top of your SAFC to get full features of Emanage. Link to post Share on other sites More sharing options...
Jacko Neutral Newbie September 3, 2003 Share September 3, 2003 (edited) [/reply] 3. Too Lean - WHite Smoke Too Rich - Carbon Deposit at the tail pipe. You need to clean off your tail pipe and observe over period of time. Blue smoke, is to the extreme. Engine Knocking if you can hear, too late already.. to hear ping, you need a special device. Can advise where the white smoke come from ah? Cheers. Edited September 3, 2003 by Jacko ↡ Advertisement Link to post Share on other sites More sharing options...
How to tell if your coffee is good
Smell of Singapore's Rich
World’s first trillionaire may emerge in 10 years, disparity report finds
