Reset ECU and HVS
Throttleb
Normally, b4 install HVS, i reset the ECU
by taking out -ve terminal
of battery for 10 mins.
with the HVS installed, do i have to disconnect the +ve
part of the HVS tat is connected before remnoving the -ve wire of my battery?
[nod] thks
I asked the pros already. I also needed to reset ECU.
YES, disconnect the HVS +ve first, then take out the battery -ve to rest ECU. [thumbsup]
Normally disconnect the -ve terminal of battery and wait 5 minutes, 20 minutes to be sure.
Then connect back.
Radio and clock reset also.
Another method is to locate the fuse for the radio and clock and take it out for a few minutes. You may find this more convenient than disconnecting the battery.
Edited by Yttrium
One of the knobs is +ve , the other is -ve.
Take out whatever cables is connected to the -ve knob.
Look on the battery marking, it's there.
you show me on sunday leh..
cos all i see are the knobs on the battery......don't see any wires connected to the battery........or maybe i am blind........check my car later.
Then connect back.
what can we achieve from resetting ecu???? after installing hvs and say magfuel????
normally what i do is remove the -ve from the batt, plug out the "ECU" fuse from its socket. Wait for 2mins. install everything back then start the car w/o radio and A/c and let it idle for 5mins then turn off the engine(pulling out the key) and start engine again.
before that i will also warm the engine to ops temp.
i "learn" this from a toyota guy many years ago. dunno if this method still applies today?
Comments anyone?
Edited by Phochem
Hi, have u heard of removing the fuse for ECU? 'cos it might be a dated method of resetting the ECU and am afraid it might result to side effects. sweatdrop.gif
I installed HVS without resetting.. so the steps are? Correct me if wrong:
1) Remove +ve of HVS (but leave the +ve of batt and -ve of HVS intact?)
2) Remove -ve of batt and wait 5-10min
3) Connect back -ve of batt
4) Connect back +ve of HVS (assuming HVS -ve still on)
