60k service
Yadado
At 60k km, it is minor service.. Flush your coolant, and that's about it. If you have auto car, u can change your transmission fluid, manual trans fluid can last a long time more than auto.
Major service is at around 90k, 180k. When you change your timing belt, spark plugs, and flush all oil.
wah, you digged out a 3-year old threadsweatdrop.gifsweatdrop.gifsweatdrop.gif
Usually the 80k service is the most thorough. When I did mine at the agent...timing belt and other rubber belts, water pump seals were replaced. Also flushing of the brakes and autotranny, etc. The amount of work done may vary from one make to another. You might want to refer to your service manual for the whole list.
Edited by Vtecc
3rd Gear
80k is normally quite major service, best is to look at the car service manual to see what needs to be change.
Normally, Timing Belt (V or boxer engine will be x 2), Belt tensioner (V or boxer engine will be x 2), A/C belt, Power Steering belt, water pump, ATF ro MTF, etc..
Best is to buy all the parts from authorised stockist and bring them to agent to do the servicing (parts prices can be cheaper by at least 30% and above) wink.gifwink.gifwink.gif
