Mmythos Neutral Newbie October 21, 2003 Share October 21, 2003 DIY grounding?? i also wan to learn hahah but then think will have to hard time doing it... ↡ Advertisement Link to post Share on other sites More sharing options...
Saaber Neutral Newbie October 21, 2003 Share October 21, 2003 no hard lah... Link to post Share on other sites More sharing options...
Saaber Neutral Newbie October 21, 2003 Share October 21, 2003 Waja got a lot of stuff lah across the causeway... Link to post Share on other sites More sharing options...
Mmythos Neutral Newbie October 22, 2003 Share October 22, 2003 grounding is to join the negative terminals to the battery rite? Link to post Share on other sites More sharing options...
Remygenn Neutral Newbie November 17, 2003 Share November 17, 2003 Hmm .. been searching high n lows for the spark plug info - kenot find them. Anyway asked the mech - they mention NGK-R (BKRBE - 11) .. hope this helps Link to post Share on other sites More sharing options...
Hitman Neutral Newbie November 17, 2003 Share November 17, 2003 Like one of my friend who was 'shocked' that I traded-in my 23mths car for a new car. First thing he say 'you siao ah, so fast change car, kanna 4 D or toto is it!' so I explain to him that I'm doing this so that I can stretch my loans longer (10yrs loan instead of 7yrs) & the monthly installment is lesser by $200. I said that too, unless u are referring to me of course Link to post Share on other sites More sharing options...
Vtim 3rd Gear November 18, 2003 Share November 18, 2003 Anyway asked the mech - they mention NGK-R (BKRBE - 11) .. hope this helps Ok, that's NGK resistor plug with plug gap of 1.1mm, so can use Denso Iridium Only think is your mech left out the number, for NGK there should be a number, eg BKR5E -11 or BKR6E - 11, the number '5' will equal to 'IK16' & '6' to 'IK20' Link to post Share on other sites More sharing options...
Vtim 3rd Gear November 18, 2003 Share November 18, 2003 yah you said that too but I was refering to my friend from Sin Kit cause I wanted to take out all my ICE & also of replacing the stock tyres Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear November 18, 2003 Share November 18, 2003 How about BPR5ES-11S, what iridium plug to get? Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie November 18, 2003 Share November 18, 2003 hope this helps http://www.ngksparkplugs.com/techinfo/spar...1000&country=US Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie November 18, 2003 Share November 18, 2003 got more info http://www.users.globalnet.co.uk/~pbegley/ngk.htm Link to post Share on other sites More sharing options...
Remygenn Neutral Newbie November 18, 2003 Share November 18, 2003 Thanks Bro ... Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie November 18, 2003 Share November 18, 2003 welcome ! Link to post Share on other sites More sharing options...
Remygenn Neutral Newbie November 18, 2003 Share November 18, 2003 Thanks VTIM for your info .. Any idea where I can get Denso plugs from ? Link to post Share on other sites More sharing options...
Seaweed 1st Gear November 18, 2003 Share November 18, 2003 which shop you frequent...sounds good leh...like when I try to change my tyre in YHI last time due to a little cut...the fellow take look and tell me no problem lar...won't burst 1...don't waste money and change....very professional...that's why everytime I change tyre....I will go back to YHI...and my favourite is A539... Link to post Share on other sites More sharing options...
Seaweed 1st Gear November 18, 2003 Share November 18, 2003 alot of place sell....autobac got sell...stamford tyre also got sell...and many other smaller shop also have... Link to post Share on other sites More sharing options...
Vtim 3rd Gear November 18, 2003 Share November 18, 2003 BPR5ES-11S = Denso Iridium IW16 the only diff between IW16 & IK16 is the hex nut size, everything else is the same. IW is 20.6mm & IK is 16mm. You still can used IK16 by just changing the 'boot' of your plug cables from stock 20.6mm to 16mm Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie November 18, 2003 Share November 18, 2003 what is the recommended gap for iridium spark plugs ? ↡ Advertisement Link to post Share on other sites More sharing options...
Changing of Spark Plugs
Tool to change Spark Plug
Plug-and-play vaccine
Spark Car Care
Spark Car Care
Aftermarket vs. OEM Spark Plug Wires
Replace spark plugs
Replace spark plugs
Denso Iridium Spark Plug (IK20)
Replacement seal for bathroom sink plug
