How to stop windscreen wiper juttering?
Fireman
For my normal wiper, I am using the correct size which is 19" and 21" respectively but still juddering as for my Silicone wiper, I used 19" and 22" instead only judder at low speed but not at high speed.
Yo bro, not sure if you solve your juttering problem. Try Autoglym Car Glass Polish, the one with the blue label packing.
CIF did work but not 100%. Only realised after a couple of raining sessions on my car. Got so fed up and nearly wanted to break my windscreen. [laugh]
So took on another advice from another forumer, Mivec, to use autoglym. So far, been testing it out during the last few days of rain and the wiper is still wiping real smooth. So I guess the problem is at last gone liao.
Thanks to all the forumer here who gave me tips and advice on this prob. [thumbsup]
Hope this helps. [;)]
Hey....just recently encountered the same problem as you. I think its becos I waxed by windscreen. Anyway, my friend recommended that I use some alcohol to remove wax from the windscreen and the wiper blades. Seems to work. Alcohol purchased from Guardian pharmacy. Yes a terribly frustrating problem!
Thanks for the info. [:)] So far, my wiper juttering is in check.
It also seems like the lesser I wax the car, the lesser the juttering. [laugh]
Thanks for the info. So far, my wiper juttering is in check.
i think as long as you don't wax the windscreen it should be ok.
tongue.gif dejavu man.... was only thinking of posting a thread like this to advice fellow forumers when I saw your thread... wink.gif
so I am replying without reading the whole thread... hope i don't repeat too much wat others have said...
FOR THE RECORD... IT IS DEFINITELY RAIN-X DAT IS CAUSING THE PROBLEMS... [nod]
I have RAIN-X for a long time, Rain-X is a good product... but not good for front windscreens... apply it only for your windows, side mirrors and rear windscreen. This will help visibility a lot when it is raining. [thumbsup]
But do not apply on front windscreen [shakehead] it will cause your wiper to shudder in no time... and eventually your wiper linkage WILL GIVE WAY... (I just replaced mine on SAT...) due to the vibration and stress... [dead]
TRust me... its got nothing to do wif your wiper blade...
And, the only way to "cure" this permanently is to replace the whole windscreen... [nod]
[idea] give u a hint... it'll help is your insurance covers windscreen... [sly]
ya .. all that I already know since living with the problem for almost 8 months. But so far, it is not juttering that much anymore as times goes by. Anyhow, when I got my ride, the screen already have such a problem but at that time, I have no idea why and then I tried rainx once. The rest is history.
My insurance never cover windscreen. [:(]
Previous car had Rain-X; same problems faced. Nothing worked - AutoGlym Glass Polish, Meguairs, industrial cleaning solvent mad.gif. Finally a stone chip solved the problem. Replaced the glass and swore never to use Rain-X ever again.
BTW, for normal cleaning, try AutoGlym Fast Glass. Works like a charm. And change wipers once a year.
[laugh][laugh][laugh]
once bitten twice shy... your case's exactly the same as mine...
only i dumber.... after i changed my first windscreen, i wasn't convinced and tried rainx in frontscreen a 2nd time.... that confirmed the problem and i prayed for stone to hit my windscreen after that.... [laugh]
Then I dunno what is the problem. Can check the wiper mechanism since you said at high speed no problem. The slow might be too slow. Need more force.
I've finally replaced my wipers...after it started making noise again last night in the rain....really couldn't stand it anymore.
Tried getting the blade refills from autobacs...but they said it wouldn't fit my wipers. Know where else blade refills are available???...they're cheaper than the entire wiper assembly.
Thanks for the information guys!
Appreciate it!
Anyway you guys know where to get blade refills...
Tried autobacs last night but the ones they sell don't fit my wipers!
Can we use those dishes green scrub on the windscreen? Have tried using Jif. It works [thumbsup] But do not use the Autoglym Glass polish as it makes yr glass kinda too clean, thus producing friction between the wipers and screen it self.
There's got to be something wrong if your wipers can't wipe glass which is "too clean"...my understanding is that the rubber is coated to make it smooth over glass....if any form of coating on the windscreen is also required....it means there's probably something wrong with the blades...and should thus be changed....
I believe I finally understand why i was having so much problems with my blades....I waxed by windscreen. Wax contains solvents which probably damaged the protective coating on the wiper blades thus increasing the friction during operation.
It is best to leave your windscreen alone i think....additives like Rain-X and other stuff could potentially damage the rubber, and reduce the lifespan of the wiper blades...
Wiper blades are pretty fragile
