Schroder Neutral Newbie July 17, 2002 Share July 17, 2002 (edited) Hi guys Need help on 3 items. I am using the Sony MD-CD set with CD changer and a set of tweeters and original speakers. 1-- How do I stop the sound that goes ti-to-ti-to after I switch off the engine? Seems like all Sony has it. 2-- How do I stop a hissing sound from the speakers? happened after I changed the orginal Alpine set to a Sony set. Could it be the wiring done wrong? Seems ok to me. Sound test was ok. 3-- The set I am using has 2 colors but I forgot how to change them. How do I do that? I lost the menu Edited July 17, 2002 by Schroder ↡ Advertisement Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie July 17, 2002 Share July 17, 2002 Hi guys Need help on 3 items. I am using the Sony MD-CD set with CD changer and a set of tweeters and original speakers. 1-- How do I stop the sound that goes ti-to-ti-to after I switch off the engine? Seems like all Sony has it. 2-- How do I stop a hissing sound from the speakers? happened after I changed the orginal Alpine set to a Sony set. Could it be the wiring done wrong? Seems ok to me. Sound test was ok. 3-- The set I am using has 2 colors but I forgot how to change them. How do I do that? I lost the menu Ans: 1. I know the manual got instruction to turn of the sound, becoz I also using Sony. 2. It may HU's grounding not good. Seeking another expert or bring back to shop. 3. Wat set?? Manaul can be download from web site. Link to post Share on other sites More sharing options...
Aha8 Neutral Newbie August 28, 2002 Share August 28, 2002 Schroder, not sure if u got the ti-to-ti-to fixed. My experience with 2 set of sony also like that. If u read the manual, its a kinda of warning beep by design. In order to eliminate it, u will need to de-activate it by hard wiring. Read ur manual again and it should say something about removing some jumper thingy at the back of the unit... thats wat i remember. Hope it be some help. Link to post Share on other sites More sharing options...
Guyver 1st Gear August 28, 2002 Share August 28, 2002 Welcome to MCF!! do "hang" around to know other members!! Link to post Share on other sites More sharing options...
Vtim 3rd Gear September 3, 2002 Share September 3, 2002 >>2-- How do I stop a hissing sound from the speakers? happened after I changed the orginal Alpine set to a Sony set. Could it be the wiring done wrong? Seems ok to me. Sound test was ok. . It may take some trouble shooting to isolate it . Link to post Share on other sites More sharing options...
Et2002 Neutral Newbie September 4, 2002 Share September 4, 2002 (edited) hi Do not install noise filter, it is only a quick way out of the problem, the system sound will degrade. Should get the installer to trouble shoot and solve the problem. A properly installed audio should not have this problem. Check out the ICE forum, there are lots of discussion on this topic Cheers Edited September 4, 2002 by Et2002 Link to post Share on other sites More sharing options...
Cool Neutral Newbie September 4, 2002 Share September 4, 2002 Hissing sound could be the he following: 1. +ve cable to close to the speaker 2. the box that connects to the speaker needs to move away from the speaker HU s definetly ok. This hissing sound once almost drive me crazy,, until I move the box but it came back.(cos the box dropped behind my dashboard and i could not bother). Until I did grounding, it all gone away. regards, Link to post Share on other sites More sharing options...
Vtim 3rd Gear September 4, 2002 Share September 4, 2002 You're right, the noise filter may degrade the sound . Delphi ICE forum will be the best place to check Link to post Share on other sites More sharing options...
Vtim 3rd Gear September 4, 2002 Share September 4, 2002 I'm having a different kind of noise coming from both rear & front speaker after I installed the E-Ram . Went to my audio guy, trouble shoot & finally replaced the AMP for the rear speaker (the AMP was about 5 years old) . However, the front still have very soft 'arching' sound whenever the E-Ram is engaged . Haven't finished my grounding job yet, will most likely do it tomorrow & see whether the 'arching' sound will disappear ↡ Advertisement Link to post Share on other sites More sharing options...
Sound Proofing the car
Whole car sound proof
Right side speakers no sound
Metal grinding sound on civic
